WasserGKuehlt
WA
4CT, 996C2, MacanS
Sport Turismo variant missing as well? Wonder if that will stay GTS only in the US and that's why it's not included. Isn't it typical for the GTS variant to arrive later in the cycle?
No, it's there..
Porsche Taycan 🚨 2025 Taycan Officially Revealed! Specs, Wallpaper Photos, Videos & US Pricing 1707265364946
(the yogurt-colored one on the left)
Three body versions - Porsche Newsroom
Indeed GTS usually trails, as it gets its own distinctive look. I was only speculating (if you're referring to my posts) that with the increase in power of the base models there may be less room.
  • Taycan[2]: 300/320 kW
  • Taycan 4S5: 400/440 kW
  • Taycan Turbo: 650 kW
  • Taycan Turbo S: 700 kW
There's exactly ~200kW between 4S and Turbo, so in principle that would be split by the GTS.
Zcd1
Walloon Lake Michigan
Tesla Model 3 Perf, Genesis GV60 Perf, Audi Q5 TDi
13% bigger battery likely means a similar increase in the weight of the pack.
Oooof, since the Taycan was already "Zaftig", with a capital "Zaf"! ;-)
Not a fan of systems that require extra actions to access full power (push-to-pass).
The charging speed looks pretty spectacular though! (with a working DCFC and the right conditions...thisisarecording)
simcity
Sean
Suffolk, UK
'23 Taycan Turbo
Ah, there it is: " A soft-close function for the doors is available on request for all body and performance variants." (from The equipment - Porsche Newsroom).
Ye, of little faith; Porsche have been lurking around here, and I'm sure they've taken loads of notes for the refresh.
Interesting you picked out soft close function from that excerpt. I took from that, race track mode, allowing active pre-cooling of the battery before “a more spirited drive” 😅
Now if the new battery charges as quickly as promised, then we won’t also need a manual battery pre-heat function either.
JIP1080
JP
Atlanta, GA
Taycan GTS ST
No, it's there..
It's there in the press photos, but not called out. On the C&D page it noted some uncertainty specifically around the ST. Additionally, in the first post out breaks out the sedan and CT pricing, but omits the ST, hence my question around it remaining GTS only in the US and releasing later.
https://www.caranddriver.com/photos...cross-turismo-sport-turismo-revealed-gallery/
Jeremy
St. Louis, MO
I’m not sure. We need specs. But from the announcement (bolding mine):
The entry level Taycan models are now also equipped with adaptive air suspension.. In addition to the upgraded equipment, the improved product specification includes a lighter battery with increased capacity.
RingoDingo
Austin
Was just thinking yesterday how wonderful soft close doors are, and how many crushed fingers my kids have likely avoided as a result. I wish I had those too.
RAHRCR
Northeast, US
Panamera Sport Turismo 4S
That front end - yeesh. Looks like it was simplified for lower cost more than anything. Looks very generic, which is too bad as the 1st gen has such futuristic styling. The internal engineering advances are pretty incredible and shows how much they’ve learned in 4 years.
Agreed. It’s not pretty from the front.
