- Jeremy
- Feb 9, 2021
- St. Louis, MO
- 2016 Macan S; 2021 Taycan 4S; 2023 911 GTS Cab
I think (technically) you would use it every time you plug into AC.I strongly believe that you will never use the 19.2kw AC on-board charger.
As far as the extra capacity over the standard AC charger, you would use it as often as you plug into an EVSE that also has a higher capacity than the standard AC charger.
And...if you install an EVSE with a higher capacity than the standard AC charger at home, then you would use it every time you plug in at home.
All of this to say your strong belief is not shared by myself.
