Chris G
- Chris
- Dec 22, 2022
- Boston
- 2022 Taycan CT4S Neptune Blue
- #1
I think I've considered the charging option less fully than I think. I've read that people, when the consider optioning the 400v/150kwh on board charger, to be doing that for when Tesla opens up its superchargers. But, is there more to it than that.
I think I saw somewhere that some EA 150kw chargers are built on 400v architecture. I assume that means that if you don't have the onboard 150kw option you will only charge at those stations at 50kw (the standard build option on Tacans).
Here are my questions that I don't have answers for:
1. Are all EA 150kw chargers built in 400v architecture or they built on 800v architecture or is the answer some of each? Does that apply to other chargers built by ChargePoint and EVGo for example?
2. Are all 350kw chargers built on 800v architecture? If not, is the answer same as above?
3. If there is an EA station with 350kw chargers and 150kw chargers are they built on the same architecture or can the 350kw be on 800v and the 150kw on 400v?
Say you have a 500 mile trip and need to make two charging stops. If you happen to only come across 400v architecture charging stations that would mean about another hour and a half for you trip. If you do that trip often, that seems something to consider.
Does anyone know the answers to my three questions above?
