jijitalia
- Mar 3, 2022
- Monte Carlo
- Taycan RWD-ASTON DB9-DB11-CooperS-BM530e
- #1
It may help some around there
Just change (myself) the winter set from Porsche (full mount Wheels+tires).
NB: I do not have enhanced dampers
Jacking up each wheel, using the jacking point , I eared a "boom" on the highest point
The following wheels have done the same front and rear.
Accordingly , once set up , I give a ride to synchro the Tire pressure system (set onto Winter mode)
BUT ... on highway @ 140 and a little bumpy track , I start to hear a "Left" Crackling noise ... not every bumps , not all the time .. but loud enough to be bothered ....
I then use a Sioux method;
I open the frunk, stand into it , start to jump to lower the car and using the suspensions
I open the trunk, & do the same ....
Tada ... no more noises
If it helps .... try it before to go to the dealer where you 'll loose a lot of time and patience
