*Beep* on skipping audio tracks
DynamoCappo
Glasgow
Taycan Turbo S
I've programmed the tracks to skip using the diamond button on the steering wheel.
Is there a way to turn this "beep" off when you skip a track?
It can be deafening at points. It seems louder when you're driving at higher speeds.
Had a look through the forum and no one seems to have asked it so far and there's nothing obvious in the menus that would isolate that noise without muting other sounds you might want to retain like the satnav audio etc.
I'm assuming there must be a really obvious way to do this that I'm missing.
Moonstone
Scotland
Taycan GTS, R8 V10+, Q5 Edition 1
I've done the same as you but I don't get a beep between tracks. Does this happen with all audio sources?
DynamoCappo
DynamoCappo
Glasgow
Taycan Turbo S
I'll check. Haven't used anything other than the phone and audio player. Maybe it's an android auto thing.
Are you iplay instead?
DynamoCappo
DynamoCappo
Glasgow
Taycan Turbo S
Finally sussed what this was!
Turns out it wasn't an Android Auto thing or even the car itself.
It was from the audio player I use called "PowerAmp" and there was a button in their settings to disable the *beep* in the Headset/Bluetooth settings!
Delighted to have figured that out.
