Boot / Trunk close button on centre console fault
848EVO
Does anyone have this issue with their Taycan?
From the centre console I can open the boot or trunk, but the close button does not work at all. From the same screen the other buttons work (frunk, charging ports).
I have the latest software update.
The rear boot can be opened by the central display with a quick press on the screen.
However if you want to close the lid, you need to hold the button until it is closed. When you close it this way from inside the vehicle it will also sound a beep when closing.
Did you press the button all the time?
848EVO
Thank you Scandinavian, that worked. I’ve never had a car where you have to hold down the interior boot close button!
