Connect App and Remote Control of Climate Control
esortho
Soren
Stockholm, Sweden
Isn’t the countdown “time used to cool”? That is, the Taycan will use 1h to cool the car to your desired temperature. The same timer is in the dashboard as well.
SmallTH
Theresa
Victoria Blackburn South
ford
Hi, when I bought my wife a car six months ago, I was also interested in this. But I was told that you need to configure it yourself. I decided that buy her a car and forgot about the climate control and about what I was looking for the remote distance for air conditioning. But after a while it became very hot and then I decided that I needed to set up the climate control as soon as possible. I asked everyone I knew for advice. And in the end I decided to go to https://www.socool.sg/, my boss recommended them to me. as a result, they very quickly installed climate control and connected me to the remote control.
Dee
Dee
A lot
+1 on that. If you try to switch to range mode, AC switches to Eco mode. When you go back to normal or sport, the AC remains on Eco. It should be displayed on your control pad what type of AC you are running - just below the set temp
On my car, the airco goes from eco (or eco plus) to normal again when I go from Range mode to another mode.
I just tried it.
Dee
Dee
A lot
I don't think it matters if you set the temp lower to speed up cooling.
The system acts upon desired temperature and actual cabin temperature.
The higher the difference, the more action should be initiated.
I didn't try direct cooling by the app though, only by charging profile.
I can imagining that that "1 hour" is key here.
In fact you are telling the car you want to leave within an hour so it calculates what fanspeed is needed, probably the lowest cuz it has a whole hour to get there, right?
When you use a profile it's clear you have a fixed time for leaving so it knows when to start cooling/warming.
Just my €0.02.
svp6
MN
4S
Just my €0.02.
Not sure - my impression is that the 1 hour is there to switch off AC in case you did not make it to the car and it does not keep draining your battery.
You are correct on the switching AC back and forth. First time I used the car, range brought up Eco AC and stayed like that also in normal. However, once I switched to full AC in normal, it remembers that setting and keeps it when toggling between modes..
Dee
Dee
A lot
You made me thinking so I tried again: it DOES START in ECO (Normal mode) and stays in ECO, no matter what mode.
Only AFTER you switch off ECO in Normal mode (or any mode) it'll change when you change modes.
That is indeed wierd.
In fact it's annoying!
Just like all the other settings (regen, sportsound) in the different modes, it just isn't stored, very very annoying... cuz ride height IS stored on different modes... >:-(
Dee
Dee
A lot
Update:
I locked the car and waited 15 minutes.
I opened the car and guess what?!
It has stored my setting!
In Range mode it does ECO and on the other modes it doesn't.
Unfortunately it doesn't remember ECO plus in Range mode (although I selected it in the menu).
I'll keep an eye on this...
Dee
Dee
A lot
Update:
Tried again and it hasn't stored it...
It starts in ECO again (Normal mode).
Man, this is so annoying!
Hi, I am not sure I follow you here.
I think that if I lower the temperature that increases the action! And that is what I wanted since the cooling was not sufficient.
I have had no luck at all today to even connect to the car. And it used to be very good coverage here, so I suspect there is some issue with the Porsche server connection? I have not been very happy with the connections between my phone and the server/car.
I have tried to use the precooling feature quite a lot over the weekend as it was more than 35 degrees Celsius and the car was very hot, but no luck. Had to open unlock car and manually turn on aircon to be able to sit in it.
Has anybody else had these issues or is it my car that loses connection. The cellular coverage on our phones has been great so no issues there. And the car was parked in open space.
esortho
Soren
Stockholm, Sweden
I’ve been unable to connect to the car all day and not able to login to MyPorsche or the Connect app for parts of the day so I guess they’ve had some issues at Porsche.
JC Mann
JC
Cayman S, Tesla Model S
I will try tha5 as well, but I had been discouraged by the Good to Know app about that, see screenshot
I think what it means is if you set it at 18 and it actually starts, changing the cooling to 16, it will not get to 18 any faster. My wife does the same thing at home. She reasons that 62F should get the 79F down to 70F faster than 68F setting would. In reality, AC can cool at a certain RATE. In other words changing the target temperature lower does not crank out “more BTU’s per minute.”
svp6
MN
4S
I have the same problem since last Friday. Initially I thought it was the Porsche server crashing because of high traffic with the WLG update. I called Porsche Connect support line. The guy first suggested resetting the car to factory settings (not very enthusiastic about it considering I have to reprogram everything including the garage opener), then talked with his supervisor and said several cars reported a similar problem, so he will create a ticket. They will "call within 24h with a resolution". 30 hours and change now, but I will cut them a brake, I suspect they have another bug that is not easy to fix.
I understand what you mean by the limit of cooling capacity. But my car was more than 50 degrees C inside and the A/C set to 21. It took a long time before it cooled down. It had been set to ECO mode and then the fan seems to run slow. Once set to A/C only the fan sped up. Just something to check when leaving the car that ECO is switched off and the hope that 1. you have contact with the car and 2. the car does not revert back to ECO mode by itself.
I will also hve the level of gas in the system checked later in the month as suggested.
My car does after switching it off.
Next day it's in Normal mode and AC has (again) switched back to ECO.
That is annoying . Wish the car would stay in the settings that I have set. BMW do the same with their M models. You have to set dampers, throttle response, steering etc. Each time you start the car up! You can programme two modes that you want and then switch to that.
Perhaps Individual mode in the Taycan is a short cut to quickly set it how you want.? Not close to my car now so can’t try it?
