The diagram in this thread does not have dimensions but might be useful to characterize what’s worth measuring. You might also infer some X and Z from whatever measurements you can find about the Tequipment trunk liner.Hello lucky CT owners. Could anyone share the xyz dimensions of the rear cargo area with the seats up? Or point me to a picture that has it? I cannot find one searching.
thanks!
As prev shared this review link below shows the guy putting 4 x 20" rims with tires into the CT after removing the privacy tray - not bad!Thanks.
That ain’t no tape measure! I haven’t seen one of those in decades.
he reports, rather imprecisely:
32w 40d 27h
Ah yes - apologies - just re-read your original post!That’s all with the seats down though. I will have peeps back there!
also, for future generations that come across this thread, the measuring in the first video above is at around 10:30.
Where did you order the rear bike carrier from? I have been told that it not yet availiable to order.As prev shared this review link below shows the guy putting 4 x 20" rims with tires into the CT after removing the privacy tray - not bad!
Someone else mentioned putting two Mtn. bikes in there after of course removing front wheels and placing in separately - have not actually seen that and suspect if larger frames involved may be challenging with even rotated handlebars - but even if just one bike fits decently that's a bonus for me when I do not want to use the full bike carrier, which I have also ordered .
To clarify - you can select it when build your car on the online configurator and provide the build to your SA to load to Porsche - this way (assuming they start increased production when they say they will in Sept or thereabouts) I am hoping it will come packaged in the car on delivery along with the charger etc. in Nov. or later!Where did you order the rear bike carrier from? I have been told that it not yet availiable to order.
Good luck with that.To clarify - you can select it when build your car on the online configurator and provide the build to your SA to load to Porsche - this way (assuming they start increased production when they say they will in Sept or thereabouts) I am hoping it will come packaged in the car on delivery along with the charger etc. in Nov. or later!
