MissionC
MY2020 Taycan 4S
snstevens
Sam
Kirkland, WA United States
So, I believe THESE TWO THINGS FIX THE 12V ISSUE I've had, and others have had.
1) Replacement of the 12v Battery, to correct a manufacturing defect. :cool:
2) A software update, including updates to the charging systems.
HARDWARE-------------------------------------
12-volt vehicle electrical system battery (lithium-ion battery)
Affected Vehicles:
There are 578 vehicles in North America affected by this campaign
Information:
Due to a manufacturing error, there is a possibility that the internal current sensor for the 12-volt vehicle electrical system battery does not meet the required specifications on the affected vehicles.
As a result, the charge state will be calculated incorrectly and the 12-volt vehicle electrical system battery will then be totally discharged when the vehicle is parked up for extended periods without an external power supply.
Remedial Action:
Replace 12-volt vehicle electrical system battery (lithium-ion battery).
Parts:
V04015001BA 12-volt vehicle electrical system battery Qty:1
PAF106825 Cheese head bolt, M8 x 50. Strut to body. Qty:4
Scope:
Working time:
Replacing vehicle electrical system battery ; Labor time 163 TU
Includes:
Removing and installing strut
Removing and installing wiper arm
SOFTWARE:--------------------------------------
WLG2 - Updating Software for Various Control Units VR8.7
Affected Vehicles
There are 2,387 vehicles affected by this campaign.
Updated Versions:
High-voltage power electronics, front and rear 0007
Control unit for high-voltage charger (OBC) 1079
High-voltage battery control unit (BMCe) E870
HV voltage converter 0899
Brake booster (electric brake booster) 0100
High-voltage DC charger (booster) 0990
Engine electronics (DME) 0005
Brake electronics (PSM) 0094
Driver’s seat and passenger’s seat adjustment 0064
Assistance systems (zFAS) 0355
Software Updates VR8.6 & VR8.7(marked below with * and in bold):
Navigation and infotainment: Porsche Communication Management (PCM)
- Quick Filter "Charging stations" is permanently visible in the PCM in order to select charging stations as a destination
- Last destinations and favorites, such as "Home" and "Work", remain stored
- Saved satellite map settings are optimized
- Registration via Porsche ID is improved
Assistance systems
- The functionality of Park Distance Control (PDC) is optimized and sporadic system failures that currently occur are corrected. *
Charging
- A new charging cable with a cable length of 7.5 meter can also be used in the future
- The charge state calculation is optimized and thus any limited system shutdowns are avoided.
- At-home charging is improved. Any premature disruption of the charging process is prevented *
- The calculation of the battery capacity is optimized further *
Air conditioning
- The functionality of the air conditioning is optimized: Temperature settings in the rear air-conditioning control panel thus remain constant and sporadic failures of the air conditioning are corrected
Chassis and driving comfort
- The starting comfort at full acceleration is optimized
- Possible chassis noises from the front axle area are reduced
- The lift function is improved. The set vehicle height is not lost after a restart *
- Software optimizations improve the functionality of the Porsche Stability Management (PSM) when driving downhill or during stop-and-go driving *
Digital cockpit display (instrument cluster)
- Various soware optimizations prevent the sporadic, short-lived display of various messages and thus improve the driving experience *
Seat adjustment
- On vehicles in non-Connect markets, the chosen seat memory settings of the driver's seat will now also be preserved after the driving readiness is complete
- In future, when using a guest profile, seat and ergonomic positions will be stored and will not be lost after a restart.*
Don - Thanks so much for all your work on the battery discharge issue. I was at the dealer today (had a run in with a curb so was having two wheels touched up) and mentioned I'd read about the recall. They checked and now I'm set up for a 13-Aug visit.
louv
louv
Don
Maine
UPDATE: New ver8.7 car Firmware partially fixes the 12v problem.
So, I received the new firmware last week (ver8.7). But I still have an “old” 12v battery.
Last night at 11pm, my car alarm went off. This normally happens just before the car goes completely dead.
But when I went out to “jump start” the car this morning it wasn’t dead.
So here’s what I think happened: the bug still depletes the battery, but now, with new car firmware, the car does a last-second hail-mary save and wakes up the 800v DC battery systems to recharge the 12v battery.
CONCLUSION: Get your car’s firmware updated, even if the replacement 12v battery isn’t available for you yet.
r553
Rockledge FL
981 Spyder, 2015 Cayenne Diesel, 2020 Taycan 4s
That is a disappointing report Don. Was your car plugged in with an active charge profile?
louv
louv
Don
Maine
Yes. My car was plugged in to my home charger, and I changed Timers & Profile settings.
I don’t think it is disappointing. It’s definite progress: the car did NOT go dead. It saved itself.
I expect even better behavior after my car gets the new 12v battery with corrected firmware.
@louv as normal - great follow up - I appreciate the updates! thank you!
CinVinman
VInce
Cincinnati, OH
2020 Cayenne, 2020 Taycan Turbo
Yes, much appreciated. This thread has helped me diagnose my issue and alert the dealer to check the 12V battery to see if replacement is warranted (in more ways than 1!).
snstevens
Sam
Don:
What I like best about this thread is that you are so positive and forward looking - it's a problem and it can be fixed. :like:
If you were just bitching and moaning I'd so not be following this thread....
r553
Rockledge FL
Is it possible to identify the updated 12 V battery by part number?
louv
louv
Don
Maine
Yes. I was just digging through paperwork this morning to answer that very question.
(Caveat: I know very little about how Porsche part numbers are organized, so this is verbatim from documents and work orders that have passed into my hands. Please correct me as necessary)
Old 12v Battery: 9J1-915-105-EY
New 12v Battery: V04-015-001-BA
r553
Rockledge FL
When I get my car I'll check the part number on the 12 V battery. Thanks Don.
louv
louv
Don
Maine
If you have not yet received your car, I am 99% sure you will already have the newest battery. (Cars with Active Repair Campaigns don't get delivered to Customers, they get held at Port or at the Dealership until everything is up to date)
Also... I'm not sure you can see the part number on the battery without disassembling the front of your car. You can definitely see the top of the Positive Terminal end of the battery. A strut and a wiper arm need to be removed to replace the battery. And I don't quite know where the part number is displayed.
r553
Rockledge FL
Don,
Yes I expect it has the newer battery as my VIN doesn't show any open recall campaigns.
Thanks for your efforts on this escapade.
If the planets stay in alignment I hope to have my car on the 14th.
Dlurker20
Minnesota
Taycan 4S, Acura MDX, Mini Cooper
Don,
I’m ignorant on Porsche processes...I didn’t know you could look up that info against your VIN yourself. How do you do that?
