JAGMAN
- #1
My ‘22 CT’s doors annoy me. They pop open a tenth of a second before the window lowers. I feel as if they are sequenced opposite of the way it should work. The preferred sequence should be 1) window drops, 2) door pops open (sequenced in order with the shortest time delay possible). Given that the Taycan has electrically actuated doors I’m surprised by the way it operates.
In an older 911 for example when you first move the door handle, the window lowers, then as you continue to move the door handle further, the door opens. Window, then door…. And yes, I’m only actuating the doors of the Taycan (inside and out) to the first detent.
Do you experience the same?
