Xsquid
- David
- Nov 7, 2020
- United Kingdom
- Macan S Diesel, Taycan 4s+, 996 C2 Coupe
- #1
Apparently according to Porsche GB this is required when the car is serviced. It is not part of the service and it is not cheap.
I had asked for an explanation as between the cost of the first 2 services at about £1150 and the 4 yr service plan at around £2300. The original 4yr service plan was £864 which some people have taken out:
This was the response:
“The prices were updated shortly after launch following queries from several centres that it should include the mandatory drainage checks which are required at the same time as the service. Otherwise you as a customer would still be faced with a huge bill when your Taycan is in for servicing which simply isn’t acceptable.”
I cannot help but sense something is not quite right here and am quite willing to have those concerns allayed.
Any thoughts? A somewhat expensive battery diagnostics. Also why is this not referred to in the servicing schedule?
