Austin_yeahbaby
- Sep 30, 2019
- United Kingdom
- Taycan 4S, replaced my 911 ;-)
- #1
This is a good site for those looking for a 1 pager detailing charging speeds
https://ev-database.uk/car/1116/Porsche-Taycan-Turbo-S
Home and Destination Charging (0 -> 100%)
Charging is possible by using a regular wall plug or a charging station. Public charging is always done through a charging station. How fast the EV can charge depends on the charging station (EVSE) used and the maximum charging capacity of the EV. The table below shows all possible options for charging the Porsche Taycan Turbo S. Each option shows how fast the battery can be charged from empty to full.
Type 2 (Mennekes - IEC 62196)
Charging Point Max. Power Power Time Rate
Wall Plug (2.3 kW) 230V / 1x10A 2.3 kW 43 hours 5 mph
1-phase 16A (3.7 kW) 230V / 1x16A 3.7 kW 26h45m 8 mph
1-phase 32A (7.4 kW) 230V / 1x32A 7.4 kW 13h30m 17 mph
3-phase 16A (11 kW) 400V / 3x16A 11 kW 9 hours 25 mph
3-phase 32A (22 kW) 400V / 3x16A 11 kW † 9 hours 25 mph
† = Limited by on-board charger, vehicle cannot charge faster.
Rapid Charging (10 -> 80%)
Rapid charging enables longer journeys by adding as much range as possible in the shortest amount of time. Charging power will decrease significantly after 80% state-of-charge has been reached. A typical rapid charge therefore rarely exceeds 80% SoC. The rapid charge rate of an EV depends on the charger used and the maximum charging power the EV can handle. The table below shows all details for rapid charging the Porsche Taycan Turbo S.
Charging Point Max. Power Avg. Power Time Rate
CCS (50 kW DC) 50 kW 50 kW 74 min 120 mph
CCS (100 kW DC) 100 kW 90 kW † 41 min 230 mph
CCS (150 kW DC) 150 kW 120 kW † 31 min 300 mph
CCS (175 kW DC) 175 kW 135 kW † 27 min 350 mph
CCS (350 kW DC) 270 kW † 175 kW † 21 min 450 mph
† = Limited by charging capabilities of vehicle
Actual charging rates may differ from data shown due to factors like outside temperature, state of the battery and driving style.
- Max. Power: maximum power provided by charge point
- Avg. Power: average power provided by charge point over a session from 10% to 80%
- Time: time needed to charge from 10% to 80%
- Rate: average charging speed over a session from 10% to 80%
