whan
- Will
- Nov 5, 2021
- Marin Co, CA
- Taycan RWD, Ferrari 458, Lexus GX460
- #16
Does UK Innodrive mandate LCA (Lane Change Assist, the light in your mirror that flashes), or ALK (Active Lane Keep, the one that keeps you centered in the lane and can follow curves)? Here, LCA is completely separate and unrelated. You don't need LCA to spec either Adaptive Cruise (ACC) or the ACC+ALK+InnoDrive bundleYep, remember there being a thread on it though I wonder if it may relate to the LCA option. Selecting innodrive on the UK configurator mandated the addition of LCA. Is it possible to FoD Innodrive on cars without LCA? If so that may be the sensor disparity postulated. I added LCA as absolutely wanted it, but wasn’t convinced on Innodrive so I’ll do the trial at some point.
In the US, when you order the car, you can either option Adaptive Cruise Control (ACC) which only controls speed while following another car, or ACC+ALK+Innodrive together as a bundle. What is interesting is that if you only option ACC from the factory, you can then add on ALK and Innodrive, but as separate individual pieces. ALK as mentioned before is the ability to follow the lanes and curves. Innodrive on the other hand does not provide ability to follow lanes - it instead adjusts the vehicle's speed in addition to ACC following, by using GPS data of curves and speed limits.
See below - in FoD, you purchase ALK and Innodrive functionality separately (unlike as a factory option where you get them together), and they have different descriptions
https://connect-store.porsche.com/us/en/p/active_lane_keeping_v1?model=taycan_2020
https://connect-store.porsche.com/us/en/p/inno_drive_v1?model=taycan_2020
From what I can understand, the Innodrive component doesn't seem to add that much value, and potentially even annoying as it adaptively changes your cruise control speed based on curves and speed even if no one is in front of you
The question is whether ALK when specced from the factory (as in the bundle) is better than FoD ALK. I too have heard it might be, but I personally am not convinced. That would imply that the factory option includes different hardware, but there's nothing in the option description that notes you get new hardware.
