Got a flat tire on your Taycan? Here's what to do
chrisk
Here is what to do:
1) Park the vehicle in a flat surface
2) Before you jack up you have to disable suspension self adjustment (for Air Suspension). The adjustments is reenabled automatically once you start driving, so do not move the car after you disable this
PCM > Settings > Vehicle settings > Additional chassis settings > Deactivate chassis adjustments to use a jack (check the box)
3) Open the frunk and find the wheel lock under the black cover on the driver side tool box
4) Jack the car up
5) Porsche recommends replacing high performance tires instead of patching them. You can decide if you want to pay $400-500 for a new tire or $20 to patch it.
6) Put the new or patched tire back.
7) Torque the wheel nuts to the proper torque. My manual says 118 lb-ft (or 160NM), but verify that is the correct torque for your car.
8) Put the wheel lock back to the tool box and place the black cover back
9) When you start driving you might get a red "Check Tire" warning if the tire was physically taken far away from the car for the repair. The warning will self-clear after you drive the car for a few seconds and the car is able to get a pressure reading from the sensor.
Porsche Taycan Got a flat tire on your Taycan? Here's what to do 20210310_143943
Porsche Taycan Got a flat tire on your Taycan? Here's what to do 20210310_145836
Porsche Taycan Got a flat tire on your Taycan? Here's what to do 20210310_144701
chrisk
chrisk
Thanks, great post. I had no idea the suspension had to be disabled
I already knew that because I had a Macan with Air Suspension but it took me a while to find the option buried into the PCM menu.
For the Macan you just pressed the physical button that lowers the suspension for 10 sec and it disables it.
feye
Shenzhen
Porsche Taycan 4S+ 2020
Me neither. One morning, I got to the car and had a flat tire. In the car I got this warning:
Porsche Taycan Got a flat tire on your Taycan? Here's what to do 1615420964268
I just pumped it up a bit, but got it fix later in the day:
Porsche Taycan Got a flat tire on your Taycan? Here's what to do 1615421049235
Afterwards, the warning did not go away, so I went to dealer on the way home to get it fixed.
akcpvzk
Aaron
West Palm Beach
2021 Taycan 4s
Is it bad that when I read the post title I thought "You don't take it to the dealer?"
chrisk
chrisk
The dealer asked $450 to get the tire replaced and they don't patch tires because Porsche does not allow them...
r553
Rockledge FL
981 Spyder, 2015 Cayenne Diesel, 2020 Taycan 4s
I've had two flat tires so far. My Cayenne 18 inflatable spare tire fits on my 4 S ( front or rear ). I got a spare from a Porsche recycler. The Cayenne jack does not fit the Taycan lifting points.
Porsche Taycan Got a flat tire on your Taycan? Here's what to do cayenne spare on Taycan.JPG
NC_Taycan
Lewis
Wake Forest, NC
Not an option unfortunately if you have PCCB or PSCB - but good suggestion otherwise!
riburn3
West Texas
Taycan CT4, Model 3 SR+
This. Just had to patch a tire that had a small nail go right through the center of my Boxster S. Discount Tire patched it for free. Or I could have dropped 500 bucks at the Porsche dealer.
I dunno what Porsche would have done with so many Pirelli tires on backorder.
bosch88
Andy
Vancouver, BC Canada
2020 Porsche Taycan 4S
Do you have the model / part numbers for the inflatable spare tire? Thanks.
r553
Rockledge FL
The best I have is the photos below. Be aware Cayenne jack does not fit Taycan lifting points ( Cayenne jack head is too wide ).
Porsche Taycan Got a flat tire on your Taycan? Here's what to do Spare tire size data.JPG
Porsche Taycan Got a flat tire on your Taycan? Here's what to do Model name of spare.JPG
Porsche Taycan Got a flat tire on your Taycan? Here's what to do Brand name.JPG
slothinker
Todd
San Luis Obispo, CA
911 (now sold), Toyota MR2, BMW 328i (now sold)
Most folks would discover a tire issue while driving. I average about one flat tire/year in a good year. Is the consensus here that Taycans should carry both a spare and a jack at all times? Are there any particular recommendations for jacks -- this car is really heavy. Alternatively, is this something AAA could do if you carried a spare but no jack? If I just call Porsche -- I live about 100 miles from the nearest dealer -- I presume they would send out something like a AAA service. Is that correct?
Murph7355
Andy
Porsche should do a wheel change air suspension setting that jacks the flat wheel for you :)
