phil21
- #1
Hi Tayan fans,
Does any of you know or can check on his/her Taycan what the ground clearance is, when the suspension is in "lift mode" (picture would be great as well)? I ordered a 4S and am a little worried to scrape the middle of the car on 1 slope I'll need to drive over quite regularly. My documentation says 127mm ground clearance but I am hoping that is not when in "lift mode" but rather when in "normal mode"?
Documentation also says 10,5° breakover angle but that doesn't tell me so much as I can't accurately measure that slope. So I am trying to compare to another car with same wheel base as the 4S and that passes the slope nicely. So need the ground clearance in lift mode to make the comparison with the other car makes sense.
All help appreciated to figure this out!!
thanks
Phil
thanks
Phil
