- Jeremy
- Feb 9, 2021
- St. Louis, MO
- 2016 Macan S; 2021 Taycan 4S; 2023 911 GTS Cab
Heat is a product of current and wire resistance, not power. The 22kW runs as 3-phase 400VAC @ 32A. The US 9.6kW runs as single phase 240VAC @ 40A. So the current is actually not so different. I don’t know what wire sizes they used in each though.And as a 3 phase 22 kW charger it performs well. No overheating, I guess since every phase delivers 7.x kW. But for the US if you boost the single phase to 9.6 kW you would put more amps through a single phase cable? It will get warm at 22 kW but not as hot as has been described here.
But the 40A itself really shouldn’t be a problem. Consider that other conductors in the house are carrying all of the current for the PMCC in addition to other house load without overheating (...hopefully ). If the PMCC has overheating issues, it’s probably underspec’d on wire size.
Correct me if I’m wrong but I think the 11kW is charged as 3-phase 400VAC @ 16A. If so, it’s not really comparable to the US spec 9.6kW.Mine (rest of the world) charges with 11kW and doesn't "overheat". Even with 9.6 kW that car charges over night.
To be clear, I don’t know if the US spec PMCC has overheating issues or not. I’m just commenting on comments...
