Head-up display no longer working
Axdenied
Hi everyone,
Just got my new Taycan 4S in Dolomite grey ten days ago, and already with a potential issue :(
My HUD suddenly stopped working and nothing can fix it…
- All options in settings are on for HUD
- Tried a PCM reset with the double tap in corner and nothing
- Every time I now open the car, I hear a buzzing sound from the dash.
Anyone else got this before? Went to the dealer and mechanic on service Saturday could not connect to HUD unit and therefore will need to bring it in next week….
Hoping this is not the beginning of other issues, also noticing several error charging messages.
What’s crazy is that if it was any other car I would be furious, but I love this car and it’s driving so much, keeping my cool :)
andrewket
Andrew
Vienna, VA
The same thing happened to me yesterday. What are the chances of that? I tried to locate a fuse for the HUD but was unsuccessful.
dgompper
Iowa
2021 Taycan 4s
This happened to me last month. I took it in, the service department hooked it up and it immediately returned to life. No issues since then.
andrewket
Andrew
Vienna, VA
Hooked what up, exactly?
dgompper
Iowa
2021 Taycan 4s
I assume their computer that scans for error codes. All I was told was as soon as they plugged it in (to that device? system?), HUD came back on.
Axdenied
Axdenied
Unfortunately when they connected their computer, all they told me was that it could not detect the HUD…. And so it’s either a fuse or a dead HUD. But could not check further on a Saturday…..
Axdenied
Axdenied
Wow, this can’t be a coincidence… also noticed in the logs that a medium level OTA was pushed also yesterday… wondering if this is what caused it.
andrewket
Andrew
Vienna, VA
This would be good to know so I can stop troubleshooting. It also means we might have to wait awhile for a fix. It was working just fine .. and then it wasn’t. The car was parked.
Njsimons13
Jason
New York
Taycan GTS (on order), Taycan 4s, Q8, SQ5
Where would you find this info? Medium level OTA
andrewket
Andrew
Vienna, VA
Talked to my dealer today. A replacement HUD is on order, but Porsche provided the tech with a new procedure they would like him to try before replacing the unit. Unfortunately the next available appointment is 3.5 weeks away. Perhaps by then the part will have arrived so if the ‘soft’ procedure doesn’t work they can still fix it with the hardware swap.
Anyone else?
andrewket
Andrew
Vienna, VA
Dealer returned the car today. Hardware swap wasn’t necessary. The “procedure” porsche gave them worked. I don’t know exactly what they did, but they did disconnect the 12v for 30 minutes. My service advisor mentioned new software, but it’s not mentioned on the invoice.
Briboynyc
Brian
Dallas
Etron GT
Today I noticed that my HUD stopped working. I climbed in the car and heard strange buzzing sound. Didn’t give it much thought but as I was driving I noticed the HUD wasn’t working. I even tried rebooting the MMI but to no avail. Now when I enter and exit the car (powering up and down) I hear this strange buzz but still no HUD.
Interesting part I was googling this problem for an Audi etron GT and I found this posting for Taycan. Since they share many of the same parts (I have a part in my frunk that says Porsche) I'm wondering whether or not the HUDs are problematic across both cars
Axdenied
Axdenied
Only way to fix it in my case was to
Unplug the 12v battery for 5 min for a reset.
faroutinNM
Mark
Albuquerque, NM USA
I've just experienced the same HUD failure symptoms, so I've now joined the 12v-Reset Club. This is the first real issue I've encountered with my Turbo, which was built during February 2021, in which an item actually ceased to function properly without healing itself after a brief time. If nothing requires more serous repair work than this, I'll remain a delighted Taycan customer
The reset did indeed resolve the issue quite well, and without undue complexity, but I would like to mention a few tips for other HUD-lovers in the forum that might have this issue:
During this reset procedure, it's a good idea to let the driver door remain open. You cannot easily open the door while the battery is disconnected.
The manual describes how to access the battery, but it's simple enough to mention here. Just open the frunk lid, lift the hand recess openings on the cover immediately behind the frunk, slide the lid toward you, and set aside (I just let it rest flat on top of the frunk cargo space).
With a 10mm socket and short extension, loosen the negative terminal clamp nut. Lift the clamp off the post (I gently used a flat screwdriver as a lever), slide a flat sheet of electrically insulating material (for example, thick paper) between the clamp and the top of the terminal post, and let the clamp rest on this insulating sheet to prevent contact with the post for a few minutes.
Reverse the procedure and verify that the HUD is operational.
The Taycan might throw a few initial startup type notifications, like one telling you to press the brake to calibrate the brake sensor, etc. Your personal settings should remain intact.
Climax_F82
Los Angeles
www.instagram.com
22 Taycan
If you mind send me your VIN, I can try to check what job they did to fix the hub.
