Hesitation during gear shift
TaycanNJ
NJ
Coming from a Tesla, I have to say that the gear shift is more noticeable than I thought it would be. I haven't experimented with it enough, but it seems like there is a difference in the shift timing depending on the mode you are in (normal, sport, sport plus). I've found that when I'm in normal mode and I come onto the highway at 30-40mph and then put the accelerator all the way down, there can be a significant hesitation in power during the shift. It also seems like the shift happens at different speeds and different points during acceleration, I'm not sure why that would be - before I drove the car I assumed it would always be at low speeds as it was mainly for the fast launch ability combined with better accelerations at high speeds.
The smoothness of the transmission is one of the main appealing factors of an EV for me so this is a bit of a negative for me. I already find myself looking forward to the second generation Taycan and I've only had the car for a month.
Is this normal? Is it affected by the modes? Is there a way to always start the car in Sport Plus mode?
Advertisement
I think this is very normal! If you ever have driven say a BMW M5 in the different modes you will notice the same. If you are in Sport Plus mode things will be much sharper than on the other modes.
What is your surprise with this?
TaycanNJ
TaycanNJ
NJ
  • Thread starter
  • Thread Starter
  • #3
I think everything with this transmission is a surprise as it has never been done like this in an EV. To me, it seems like a bit of a compromise from Porsche. I would be surprised if they don't find a way to eliminate multiple gears in the next generation or maybe even with the release of the electric Macan.
Either way, I guess it just becomes part of the startup process to turn the mode select two clicks to the right for Sport Plus. I tend to do it after I pull out of my driveway as I need the suspension higher, and i find that the shift occurs while changing from normal to sport plus and the hesitation/stutter that occurs varies depending on speed while changing modes.
Minor annoyances in an otherwise amazing vehicle.
PanameraFrank
Seattle
I have not noticed it at all in Sport or Sport Plus but I'll never drive the car in Normal.
They certainly won't eliminate the transmission, it has significant benefits & they've invested a lot into it, but they will likely make it smoother in normal mode.
Then again, I advise against ever driving a Porsche in normal mode. Ever. Even with the Taycan it's Sports, S+, or Range for me.
charliemathilde
CA
In Range mode, the car won't use first gear at all. No shifts.
Ironically, it'll be more shift happy in sport plus as it tries to maximize your torque at all times.
but at lower speeds it'll probably stick to 1st gear all the time
remember this is only the rear motor. the front motor is always active, and never shifts and is providing full power even during the shift. You never have a moment of reduced power like an ICE car with the clutch engaged
svp6
MN
4S
Just like @PanameraFrank said, drive the car in Sport mode. I noticed too the hesitation in normal, and that the car is really quick in Sport mode. If you think about it, your Tesla was probably set in "sport" not "Chill" mode too...
The most irritating part is that the car does not remember the driving mode I left it in, nor is there a way to start in a pre-defined mode . It stubbornly goes back to Normal so I have to change each time. My Merc did the same - back to "Comfort" no matter what.
I also think my car has a case of early Alzheimer. Half of the times it forgets to adjust the mirrors until I push the memory button, half of the times it does it on its own...... Considering there is only one profile saved, and I am the only driver, it should probably not be that confusing
dryii
Doug
Orlando, FL
I, too, was annoyed coming from a Model 3. Pushing down the Taycan accelerator seemed sluggish in Normal, what I've been referring to playfully as 'turbo lag'. After discovering this didn't happen in Sport and Sport Plus I'm constantly switching to the latter every time I get it to drive.
KensingtonPark
New York, NY
2020 Porsche Taycan 4S; 2020 Audi A7; 2019 Hyundai Elantra GT; 2020 Hyundai Kona Ultimate
Do you use the same key every time? Our Audi links profiles to individual keys.
Advertisement
Advertisement
