Horrible cell phone reception in Taycan - any solutions?
andrewket
Andrew
Vienna, VA
I believe the antenna “booster” is passive. There is a plate behind there connected to a feed line that routes to a small panel antenna. It’s better than nothing. I generally only have problems in rural areas so I don’t bother.
I’m having bigger problems with my ezpass toll tag. It doesn’t work no matter where I place it. I tried the license plate version under the bumper but that didn’t work either. As I don’t have a front plate that’s not an option. I could try a license plate tag on the rear … but I suspect I’ll have to drive really slow :(
Advertisement
MJH_102383
MJH_102383
Michael
Chester County PA
2020 Taycan Turbo S; 2019 Cayenne; 2017 911S
I’m going to try the storage tray in the morning. I have my phone in a case. I have to remove it to use the tray. What a pain in the a$$! 200K car and I can’t make a call…crazy!
When I say I absolutely could not agree more I really mean that. I couldn’t care less about any of this glass or whatever other excuses there are as far as I’m concerned for a $200k+ car there’s zero reason cell phone service should be an issue. From a safety standpoint and even something as simple as navigation, when I’m on the Navi on my phone it literally messes up the directions because it loses service!!
MJH_102383
MJH_102383
Michael
Chester County PA
It might be 5G related if that is what you currently on. I have AT&T with iPhone 12 and the signal in my condo is nearly non-existent now that they upgraded to 5G. (I have not really checked it in the Taycan but now I will look).
My wife's iPhone 12 has no signal either, however her iPhone X and 11 both have perfect signals with LTE (yes, she has three phones). I suspect is is 5G related because the iPhone 12 s are the only ones on it. I may be wrong of course.
My thought is is due to the extra thick thermal insulated and polarized full glass walls that are in my condo. I only have one exterior wall that is not glass and that faces the interior hallways.
If I go out on my Lanai, perfect signal.
I believe you are also correct! But what’s insanely frustrating in the iPhone 12 Pro Max with 5G turned off, the issue doesn’t get any better!! I keep telling myself if I hang in there until October maybe the new (not released yet) iPhone will work in this car!!
jimithing
Jimmy
USA - Mid-Atlantic
Same issue with EZPass although I did improve it by putting it vertically in the special zone next to the mirror. My area is changing to pay by plate anyway so I simply ignore the misses. They figure it out.
Jmrdmd
Jan
NJ
2021 Taycan Turbo S
Good Morning
So I placed my iPhone, case and all, into the holster in the center console and what do you know, it worked great! I talked for my entire ride to work with no dropped calls, no "can you hear me?", just excellent clarity.
Thanks again to this forum and all who contribute! I know that I wouldn't have tried this if it weren't for this post!
Best
Jan
MJH_102383
MJH_102383
Michael
Chester County PA
Good Morning
Best
Jan
For the love of god I hope this works for me as well! Did your phone screen face you, I take it?
Jmrdmd
Jan
NJ
2021 Taycan Turbo S
No, I placed the phone in the holster with the screen facing away from me. Like if you would to charge it on the inductive charger, you want the back of the phone to contact it.
Best
Jan
kort
'21 taycan 4s
Best
Jan
be aware that if you run apps like car play, waze, while using the holder the phone will run extremely hot
struther
Brad
Toronto
Nissan GTR, Nissan 350z
If you turn off wireless charging, will the signal booster still work? If so, probably want to try that to avoid the excessive heat issue.
KTC
Keith
PNW
2017 911 C4GTS; 2020 Taycan Turbo
This was not how I was hoping to solve my texting while driving problem.... sigh.
TycanNewHampshire
TG
New England, USA
Tycan 4S
....I’m having bigger problems with my ezpass toll tag. It doesn’t work no matter where I place it. I tried the license plate version under the bumper but that didn’t work either. As I don’t have a front plate that’s not an option. I could try a license plate tag on the rear … but I suspect I’ll have to drive really slow :(
I can't find the picture that I found, but there are two rectangles to the right and left of the rear-view mirror mount that they have removed the laminate to allow ez pass to be read through this....I have mounted mine at that angle flush to the rear-view mount (it is almost vertical) and it has now been registering just fine....you just can't have it mounted 'flat' or parallel to the dash/road. I will look for the diagram/picture if I can find it.
Bry5on
CA
'70 electric Jaguar, Taycan 4S CT due October
My iPhone works annoyingly well. Better, even now that I switched from ATT to T-Mobile.
Do you have the thermally and noise insulated glass or no?
my build locked a couple weeks back but I’ve asked the dealer to remove the glass option based on this thread. Can’t imagine how frustrating that would be, definitely not worth some noise reduction
XLR82XS
LXA
SW FL
2021 Taycan | 2021 Cayenne GTS | 2018 991.2
We have the insulated glass and my wife has issues with her phone (iPhone X) in the car. But I have an iPhone 12 and do not have any issues.
Interestingly, she also has issues with the Apple AirPlay (Bluesound Node 2i) for our basement, but I do not.
I told her to get a new phone, which I thought would fix both issues. But now I’m not sure.
Full or standard insulated glass? thermal glass is standard. I have zero reception issues - iPhone 12 as well (if that matters)
Advertisement
ZYRUS
Advertisement
