- Jul 30, 2021
- WA, USA
- 2023 Taycan TCT, 2024 Q8 eTron P+
Remember not to keep a spare set of keys out of a faraday's cage box.I did buy a keylessgo box after this video
If they do the relay attack, or any attack which successfully impersonates the key, the charge port unlocks. If they are brute force stealing the car via a tow truck, cutting the charger cable is trivial (and fairly safe as the charge has many safeties built into make sure nobody gets hurt). The charger really only serves to protect against opportunistic thieves if you leave your keys in the car, and the thief cannot figure out that they need to unplug before driving (would take some really dumb thief).the charger also works as an extra lock and then there is intrusion and gps alarm.
Sometimes it works, though obviously not in that video. Well lit parking is generally a good idea.Big floodlight with movement sensor shining over the car, Not sure what else you can do.
Bottom line is if someone really wants to steal your car and they are smart and determined, there isn't much you can do to prevent that. That said, you cannot live your life in fear of what might happen - that's why you get car insurance. Following a few common sense things, such as a faraday cage for your keys if you regularly part outside on your driveway, never leave your car unlocked, etc. should be sufficient.
PS> I wish car manufacturers would implement more secure keys. A simple idea would be for the keys to disable all transmissions after a period of no motion. So, if you place your keys on a table, or hand them, 30 minutes later they can no longer be relayed. In the car it's not an issue at all as the car is in fact moving, so there will always be motion detected on the key, and even if there wasn't, the car doesn't just grind to a halt if the key was in the car before and suddenly is not detected. There are more advanced (also more expensive) ideas to prevent relay attacks too.
