How do I lock my 4S without enabling Interior Monitor Alarm?
PDACPA
PDA
Tampa, FL
I always press park button only, open door, lock with key fob while walking away or lock with button on truck lid. Never had a car alarm. Maybe faulty sensor?
Dealer will look at when it goes in for one of the missing parts. I think mine is related to the incline sensor. A few have issues with the interior monitor.
Giovannie
Jan
Holland
Boxster S, Panamera 4S, Taycan 4S
I got the same problem with my Taycan 4S, which was delivered last Wednesday. Car in the garage and interior alarm going off (repeatedly, irrelevant how I closed the car).
Reported the problem to my Porsche dealer today and they confirmed that it is a known problem to them and to the Porsche Factory. And they advised the workaround as posted in this thread by PDACPA (turn off the interior alarm).
They will come back to me as soon as a solution is available. I hope it will be soon.
PDACPA
PDA
Tampa, FL
I have also been using the double click on the key fob (defeats having comfort access lol) and watching for the two fast light flash and the longer 3rd flash. Works perfect too.
TayFan
Jason
Northern California
Porsche Taycan 4S, Audi A7, Mercedes ML350
In the PCM, Vehicle, Locking (going from memory but you can find it), you can turn off Interior monitoring (which mysteriously turns itself back on when it wants), but further down it has the choice to "Ask" if you want it on each time.
The trick is you have to power off the car and DO NOT OPEN THE DOOR and wait for the question to appear on the PCM, uncheck the interior alarm box and then press the "X" in the corner. Then you can open the door. If you open the door before, you do not have time to react with the message.
Of course most of us turn off the car and open the door.
The double lock key fob press works well though. You get two quick light flashes and one long to confirm and that is what I have been doing.
I have noticed, it happens more on my driveway incline than when the car is flat, but it does go off when on flat surface too.
Clarification question please:
“ The double lock key fob press works well though. You get two quick light flashes and one long to confirm and that is what I have been doing.”
Those light flashes you’re describing here to verify the interior alarm disable mode…are those on the interior alarm red alarm LED light, or the exterior lighting (parking lights etc)? Was curious if external lighting has any diff blinking scheme depending on lock alarm status. Thanks!
PDACPA
PDA
Tampa, FL
The light flash is the head light and amber side markers out side of the car. Get out of the car and press the lock once. I think it does 2 quick flashes. Unlock the car open the driver door and close it. Then do two fast clicks on the FOB of the lock button and watch the lights. You will see the last flash holds the light on for a little longer than a flash. That is how you know the interior monitor is disabled.
TayFan
Jason
Northern California
Yes, ok. I wondered if that’s what you meant. I see it. Thank you very much.
02bluesuperroo
SE FL
2022 Porsche Taycan 4s
Supposedly Porsche has issued a new part to replace the interior monitor sensor which will fix this issue. My car is going in next week to hopefully get it replaced.
Hirschaj
Jim
Austin TX
Can you post the old and new part numbers in here after it gets replaced?
jimtoniq
Cologne
Taycan 4s Cross Turismo
Can confirm. I had the same issue and the motion sensor was replaced two weeks ago against a revised version. I have had no more false alarms since.
McgR
Taycan CT 4
Good news. So my CT4 that goes in to production should be Ok.
02bluesuperroo
SE FL
I took mine to the dealer for this issue and they said they're not authorized to replace any parts. They only offered the workaround as a resolution. They even provided a bulletin from Porsche which indicates that they're not authorized to replace parts for this issue and they should tell the customer the workaround.
I'm truly disgusted with this solution from Porsche. 3 years and they cold have just eliminated the feature knowing it doesn't work but instead they'll happily sell it to customers and laugh all the way to the bank. I'm really starting to sour on my purchase and I wish I would have gotten an EQS instead at this point.
02bluesuperroo
SE FL
I completely understand and can relate. I do know that Porsche na is aware and from what my SA said they’ve passed instances of it onto them in order to aid in isolating the bug. I just want to figure out a definitive work around because this unfortunately isn’t a bug that can be easily overlooked or ignored given how disruptive it can be :)
Porsche saying they're working on a workaround for this issue is just a front. They have been having this problem since the 2020 model year. See the attached bulletin from Porsche for proof. They're content to sell you a car that has non-functional features. Not only is the interior monitor not functional, but as a result you also cannot use the trunk's close and lock feature and you cannot lock the car from the mobile app either so there are several features effected.
jimtoniq
Cologne
As far as I know that is BS. The Bulletin is from November and was valid at that time since they had no clue what was causing the issue. Changing any parts then would not solve the issue as the faulty sensor might have been replaced against a new but still faulty one.
Based on my own case (I can only assume) the sensor must have been revised and the new one does not cause the error. I got the info about the fix from my dealership late December. I could imagine that they currently simply do not have enough sensors (yet) for all markets and are therefore not publishing the solution just yet. Just assumptions of course.
I hope you guys get yours fixed soon. Since the alarm issue is fixed I am a happy customer and absolutely love the car. Not had a single glitch since (fingers crossed it stays that way).
Skilly
Matt
Livermore CA
2020 Taycan Turbo
I get a 'good bye' message on the PCM with a toggle to turn on/off the interior monitoring every time I leave the car.
ismelllikepoop
Dennis
socal
911 T
We did the same, but sometimes it just decides to turn itself back on. No one drove the car for a few days, had the interior monitoring off. Don't use the app or anything and randomly went off after two days of quiet. How the hell has this been an issue for this long,l it's nuts.
