Saloon - Park Assist on, select rear camera and touch the wash icon.is this a standard feature still? I don’t seem to see a button for cleaning the cameras.
CorrectAhh I found the button — amazing! There's no washer for the front, right?
Saloon = Sedan and has all trim levels.Is Saloon the base model?
I may not be correct and what I saw in my GTS might be coincidence but I recall recently cleaning my front windscreen with a long press (I was testing to see if my washer system was working as it should - it isn’t and is getting looked at soon) that when I got out I saw washer fluid dripping from under the front camera.Correct
There is no front camera washer nor a need for itI may not be correct and what I saw in my GTS might be coincidence but I recall recently cleaning my front windscreen with a long press (I was testing to see if my washer system was working as it should - it isn’t and is getting looked at soon) that when I got out I saw washer fluid dripping from under the front camera.
don’t know if anyone else gets that though. Tbh not tried it in our CT to see if it happens on that too
More than likely true as you’re right I’ve not seen a washer spout at the front!There is no front camera washer nor a need for it
It is probably the water from the windscreen when deluged finding its escape route to ground.
Maybe a pipe has come off in the wiper washer system if it isn't working and washer fluid is dripping out the front.I may not be correct and what I saw in my GTS might be coincidence but I recall recently cleaning my front windscreen with a long press (I was testing to see if my washer system was working as it should - it isn’t and is getting looked at soon) that when I got out I saw washer fluid dripping from under the front camera.
It’s booked in so they can look at it. Not sure if I should given I know nothing about how to fix itMaybe a pipe has come off in the wiper washer system if it isn't working and washer fluid is dripping out the front.
There is a "water jet" that cleans it. Put it in reverse and an icon should appear in the instrument cluster just above the reverse cam icon on your photo above.
Ah, noticed it's a CT. Then push and hold the stalk forward to engage the rear wiper and the camera cleaner thingie.
