How understand battery Plus and heat pump
miglio
Italy
Taycan 4s - Cayenne Coupe Hybrid - Carrera S 992
Hi guys
How can I do to understand if in my taycan 4s I have installed Battery plus (93kw/h) and heat pump...
i have chosen these optionals but I have not possibility to se and check them
thank you
Dlurker20
Minnesota
Taycan 4S, Acura MDX, Mini Cooper
Hi guys
thank you
Battery Plus is a larger capacity battery that improves range and performance.
The heat pump will warm the batteries to improve efficiency.
miglio
miglio
Italy
thank you Dlurker20 I know that...
I have put these 2 optionals Into my taycan
my question is where can I check in my car if these 2 optionals are installed on my car or not ?
that’s like checking if your car has a twin-scroll turbo - how do you know with out tearing it apart.
the battery is the easiest - range reported on the main dash at 80% charge should be 240 miles or more - if it’s charged to 80% or more and range is reported in the low 200’s you have the smaller battery (most likely)
the heat pump is an internal thing and you’d have to tear the vehicle apart to find it - I’d suggest Porsche is not going to rip you off and if you ordered a heat pump you’ll get a heat pump.
miglio
miglio
Italy
clear
thank you very much
