j.w.s
- Jeff
- Oct 26, 2022
- San Francisco, CA USA
- 2023 Taycan GTS, 2024 Rivian R1S
- #1
To preserve battery life, Porsche recommends charging to a maximum of 85% for daily use, using 100% charges only for longer trips. This is a Lithium battery thing, not a Porsche thing, often discussed on the forum. I know quite a bit about batteries, so preserving battery capacity over time is something I think about.
Other discussions talk about 22kw, 11kw, and 9.6kw charging, and of course fast charging up to 270KW. Faster is better, right? Except that faster charging is slighly more harmful to the battery, at least after many hundreds to housands of cycles.
Here is my observation after a few months of ownership:
I recently changed my day-to-day charge level from 85% to 75%, and I changed my EVSE maximum charge rate from 48A to 24A via its software. Doing so very likely extended the lifetime of my battery pack by up to a few years, and yet I do not notice any inconvenience at all, and here is why:
My typical Taycan drive is <100 miles, for which a 75% charge level is more than enough. Right now, at 75% charge, my GTS on 21" wheels says it can drive 178 miles. If I do plan a longer trip, I'll know the night before, and I will use my phone to activate a trip timer with a higher charge percentage. Even a last-minute longer trip typically gives me an hour or more to top-up if necessary, bringing the charge level up while I go about my morning business.
When I get home from a day of driving, having used say 40khw, an overnight charge at the slow 5.7kw charge rate is more than enough to top back up to 75%, gently.
So even though I software-neutered my battery capacity and my charge rate both, the car is no less convenient to use, ever. 90% of the time I just drive, longer trips take just a timer, and worst case, I might someday spend 30 seconds changing the EVSE charge rate and the Taycan charge timer and I'm back to 11kw charging and any charge percentage I need.
I'll say it again: If you are like me, you may be able to charge a bit more slowly and leave the battery a bit less full, without even noticing, while improving your battery health over the years, just in case you plan to keep the car for a very very long time like i do, or in case future used EV sales norms include stating the battery state of health - which they should.
