Jacking pads and lifting points for Taycan
NJ-Taycan
Chuck
Deptford NJ
2022 Taycan 4S Cross Turismo
Did a search and found many posts, but nothing definitive. I need to jack up the car this weekend to switch the tires for winter wheels. The jacking points look square and proprietary. Would I be safe using a floor jack with a hockey puck or has someone found a particular jacking pad that fits into the channel and provides proper and safe support?
RBGtaycan
Bob
Long Island, New York
Kia EV6...Past: 2021 Taycan RWD; 356, a couple of Cayman S
heads up: if you have air suspension, read the manual about how to jack the car with air!
jcg
NEW YORK
21' BMW X5, 22' Taycan GTS
Have the same ones - Creative Steal Work well. Had to put my GTS sedan into lift position and then select jack mode in the pcm.
found that my floor jack did not quite fit under the car from the front lift points when attempted first but when I started with the rear tire first and jacked up the car, I was able to get the jack under the front (if that makes sense)
NJ-Taycan
Chuck
Deptford NJ
Just ordered a pair of Creative Steel for overnights shipping. Yes, will put the air suspension in jack mode and my low profile racing floor jack should have no problem getting under the car.
Reactions: jcg
NJ-Taycan
Chuck
Deptford NJ
Jacking pads arrived via FedEx overnight. Will be using them this weekend to switch over to winter wheels. Will report back on how they work here.
