Windpower
- Ken
- Jul 19, 2021
- Long Island, NY
- Tesla Model Y, BMW X3, Taycan RWD Coffee
Today my electrician and I maxed out the load at the house and recorded 66 amps. So I can add a dedicated 100 amp circuit for the Taycan and still be safely under 200 A.
The install in the garage would be fairly straightforward as my meter base is mounted on exterior garage wall and the panel is on the same wall inside the garage about three feet away.
Originally I was just going to go NEMA 50 with the PMCC at 9.6 but the throttling and my ability to go up to 19.2 have convinced me to hardwire a charger.
+1 on backing up and thinking about your charging needs.Perhaps back up a step and consider your actual charging needs.
There are three things all EV installs need to consider:
- how much power you can spare for EV changing. The way to do this is by doing a load calculation on your house. I had an electrical engineer do this for me on my last house renovation. I have 100 amp service and I have 40 amps dedicated to EV charging and have my EVSE dialed down to 32 amps. It sounds like you can spare 100 amps for EV charging. Good!
- how many miles per day do you drive and how often do you want to charge. If you're not driving a lot per day, in most cases you can charge overnight so the amount of 'amps' you need is pretty low. I charge once a week and over night charging works fine with my 32amp EVSE.
- how many EVs do you think you'll eventually have. When buying an EVSE, if you plan to have multiple EVs, its best to get one with load sharing for multiple EVs.
I always suggest putting in the largest power possible for EV charging, not because you'll need this power for one car but in the case where you have multiple EVs. I ran 6 gauge THHN in conduit to my garage so that I'm prepared for the future. Running new wires for EV changing is something you really don't want to do more than once. Its normally a messy job.
Bottom line: run bigger wires but go with a slower EVSE. I don't see much need for 80 amp charging unless you're an Uber driver. But running power line to support 80 amps might make sense for the future.
