Low ride height of the Taycan / ground clearance?
hooneyrob
Robert
Norfolk, UK
Taycan Turbo S, Caterham 420S, 2018 Discovery 3.0.
Hi All,
Interested in your thoughts on ground clearance for the Taycan? I drive a Turbo S and have noticed the protruding air vents underneath the car often scrape when driving B roads. If there's too much undulation on the road, they'll scrape. I also feel as if the car is just going to scrape in general - even with the raised suspension setting.
In the UK, our 'B' roads are not smooth so I'm constantly feeling like I'm going to bottom the car out when driving fast.
Does anyone else hear the odd scrape as they are driving around? Perhaps I should just accept it? Sure, if you're going to drive slowly then you'll get away with not scraping the car but that's almost impossible!
Robert.
Pozuelo
Roberto
Madrid, Spain
2020 Taycan Turbo S, 2018 E63S Estate, 2023 A45S
Hi All,
Robert.
I had the same feeling, until a couple of months ago, I decided to use the Sport suspension setup. While it is much firmer, and prevents most scrapes, you must still raise the suspension on speed bumps and large angle changes on driveways and similar. I noticed that on the normal height and suspension setting, the compression is very softly set. This is improved with the sport setting while being still comfortrable. Try it out and report back.
I have the same observation. The roads around here are quite good so not too much scraping, but speed bumps are a pain.
one easy setting is as you say to put the ca4 into sport mode. I also have found that driving in Normal Mode with stiffer suspension has helped a lot. It seems more of a rebound issue than the height itself.
hooneyrob
hooneyrob
Robert
Norfolk, UK
Good advice about firming up the suspension when driving 'swiftly'. I'll try that but has anyone noticed any scrapes? I think it's always the protruding air vents at the front. I guess they can be replaced but looks like mine may have touched down on occasion.
Pozuelo
Roberto
Madrid, Spain
From below, yes. From front no...
