My guess is that since Porsche certainly could if they wanted they considered it a pointless excercise given the other compromise needed to achieve a benchmark nobody will use in real world situations.I wonder why the Taycan’s top speed even in top trim does not exceed 270kmh, despite the 2 speed gearbox.
I know gearing and battery sustained output probably have something to do with it but the Maserati has similar 0-100kmh time (no word on awd), and they must have also a consideration for battery sustained output.
Not trying to argue on the merits of 300kmh, rather curious what engineering solution Maserati have found. So far only EVs from Rimac and Tesla Plaid S can achieve these speeds. And Porsche isn’t exactly an engineering lightweight.
true, but read somewhere recently that Porsche customers actually valued Nurburgring lap times (okay maybe not the Macan customers, but generally speaking) and it is obvious that the TTS could have easily shaved a few more seconds had its speed not been limited to 270kmhMy guess is that since Porsche certainly could if they wanted they considered it a pointless excercise given the other compromise needed to achieve a benchmark nobody will use in real world situations.
Current top speed maxes out motor rpm. They’d need different overall gearing (to increase max speed within motor limits) and more HP (to keep low end accel).I wonder why the Taycan’s top speed even in top trim does not exceed 270kmh, despite the 2 speed gearbox.
One of the things listed above. Only so many ways to do this.curious what engineering solution Maserati have found.
You're probably right. I know the TTS can sit at 270kmh until its battery is drained. I wonder how long the Maserati can sustain 300kmh, and whether it will cut power (thus reducing speed) before the battery is drained. That would be another way to do this, which I think Porsche would never accept (they are all about repeatable and sustained performance)Current top speed maxes out motor rpm. They’d need different overall gearing (to increase max speed within motor limits) and more HP (to keep low end accel).
Or motor with proportionally higher max rpm.
It isn't rare for a car to be worse for its principle function in order for it to meet some marketing benchmark.but read somewhere recently that Porsche customers actually valued Nurburgring lap times
