I think the offset will be the same for all Taycans what may well be different is caliper clearance for the spokes of the Mission E wheels. The 4s caliper location is much nearer the hub so the spokes may clash with the caliper.I think there's an offset difference...
The configurator happily allowed 21" wheels on standard CT 4S so I am sure it isn't the look (though the 4S discs do look tiny in 21" wheels) I am still pretty sure based on my experience it is a clearance problem and the mission E wheel spokes will hit standard 4S calipers.To be honest, I've already purchased the rims without having the car yet In my config the car will be already on 21" wheels, but not the misssion-e ones. I plan to have the mission-e ones for the summer tires and the other for the winter.
I've already found an answer to my question:
https://www.taycanforum.com/forum/threads/21-inch-wheels-on-4s.1136/#post-15803
I think that Porsche didn't want to let putting mission-e wheels on standard brakes as they indeed look a bit worse as they are smaller and that's the only difference.
The other thing to consider here is that Porsche will not let the car have the warranty extended if it has mission-e wheels on standard brakes.
@f1eng I have the Mission E on Standard break on a Taycan 4S and enough clearance between Calipers and Spokes. However I do have an annoying breaking squeal that I still can’t diagnose if due to Mission E vibration or simple rust on rotors….The configurator happily allowed 21" wheels on standard CT 4S so I am sure it isn't the look (though the 4S discs do look tiny in 21" wheels) I am still pretty sure based on my experience it is a clearance problem and the mission E wheel spokes will hit standard 4S calipers.
No clearance problem. I’ve even seen Porsche driving with mission E on track with standard brakes.The configurator happily allowed 21" wheels on standard CT 4S so I am sure it isn't the look (though the 4S discs do look tiny in 21" wheels) I am still pretty sure based on my experience it is a clearance problem and the mission E wheel spokes will hit standard 4S calipers.
In that case I can't see any technical reason to not allow mission E wheels on the configurator without additionally specifying more expensive brakes.No clearance problem. I’ve even seen Porsche driving with mission E on track with standard brakes.
I have Mission E on my 4S standard brakes, and after 10.000km there’s no issues with brakes or caliper clearance.
Of course it’s profiteering, but I think the “logic” is because their color painted (or silver) wheels they don’t want them out there full of brake dust. I don’t think they trust us to wipe our wheels everyday….. but yes, profiteeringIn that case I can't see any technical reason to not allow mission E wheels on the configurator without additionally specifying more expensive brakes.
It is either styling or profiteering then.
No visible brake dust. Car brakes up to 3G on the motors. I’ve had zero problems with visible brake dust, only issue is dust and dirt from road or other carsOf course it’s profiteering, but I think the “logic” is because their color painted (or silver) wheels they don’t want them out there full of brake dust. I don’t think they trust us to wipe our wheels everyday….. but yes, profiteering
I believe it is 0.3g, there isn't a road car or road tyre capable of 3g braking!Car brakes up to 3G on the motors.
Question regarding that. My 2013 Model S still generates some brake dust due to the having to actually clamp pads below about 6-7mph. Can the Taycan stop with out using the pads? I think the new Teslas do…No visible brake dust. Car brakes up to 3G on the motors. I’ve had zero problems with visible brake dust, only issue is dust and dirt from road or other cars
Not much brake dust at all. Surprisingly brake pads and disc almost doesn’t show signs of wear at all.Question regarding that. My 2013 Model S still generates some brake dust due to the having to actually clamp pads below about 6-7mph. Can the Taycan stop with out using the pads? I think the new Teslas do…
You’re right! Missing a “0.” there. Porsche have 3.8m/s ≈ 0.38g.I believe it is 0.3g, there isn't a road car or road tyre capable of 3g braking!
