Mobile Charger Plus Dimensions
torx
Could somebody please tell me the length of the cable from the car connector to the charger part.
Also can you confirm the overall length is 4.5m.
Thanks
GTS ST, Macan T
Download the manual (Google Porsche Mobile Charger Plus operating manual) and you should find all details in there.
Order the no cost 7.5m cable instead.
torx
Yes tried to order the longer one but dealer said it was too late to make changes.
GTS ST, Macan T
Nothing like a helpful Porsche Dealer! You can order separately and it doesn't have to be a Porsche one.
You could also ask if they have one with their demo car and ask to swap when yours arrives.
torx
So is it simply an extension cable added onto the mobile charger plus?
GTS ST, Macan T
Yep, standard cable but just ensure you have the right connectors on either end - use the 4.5m one as a template and you'll be fine.
You will get other cables with your charger - 3 pin 13A plug and a connector to connect from your 32A supply (to get 7.4kW) to the input of your charger. The 4.5m / 7.5m.cable then connects to the other end and onwards to the car.
The manual will show this.
Xsquid
Macan S Diesel, Taycan 4s+, 996 C2 Coupe
Thanks
You will need to check this but I believe the Mobile Charger Plus is just a more powerful Mobile Charger. If so you cannot remove the connection to the car in the same way that you can with the Mobile Charger Connect and add on a longer connection ie swapping out the standard 2.5m lead for the 7.5m cable. The connection the other end is interchangeable depending on your type of power source.
GTS ST, Macan T
The mobile charger connect (PMCC) is the more powerful / expensive charger.
Mobile Charger Plus (PMC) is the standard charger free with the car.
PMCC is a 22kW capable charger in UK and PMC is 9.6kW.
