New Porsche Owner needs help with Homelink
ron_b
Ron
SF Bay Area, USA
Bolt EV, Taycan 4S (Sched Oct)
A very nice video showing how to setup homelink and also how to assign to a shortcut key.
How to Pair a Garage Door to the HomeLink System in a Porsche Taycan
Paul Steinbruner
Gogs
Gordon
Aberdeen, Scotland, UK
Taycan 4S - Soon, 911 4S, Range Rover Sport Hybrid
Paul Steinbruner
What happens if you have more than one profile? The shortcut key would not know what profile to activate?
ron_b
Ron
SF Bay Area, USA
yes I was surprised he didn't mention that but I would assume it would bring up the list in that case and you would have to hold the selection on the screen. Alternatively you could use that location-based option and maybe in conjunction it would know which one to activate with the shortcut.
Rekool3
Carlsbad, CA
2020 Taycan Turbo S, 2020 911 Carrera 4S
Paul Steinbruner
Thanks for posting this!! Just got it to work after resigning myself to carrying the remote in the car. I went ahead and passed it along to my sales rep, as he too hadn't figured it out yet.
And on we go....
Cheers
Denham
Maine
I finally got my Homelink to work after some instructions from Homelink (which still did not match the screens in the Taycan). However, it does not come up when near to the door (I used the set location button when in the same location). I have to go to the Homelink screen and click on the button there. Only a few extra steps but shouldn't it come up when close to the door?
dryii
Doug
Orlando, FL
I have the same issue. The manual says it should be displayed, or even open it automatically. As of yet I have not see this capability.
And it's very annoying to have to click through 3-4 buttons just to open the garage door.
ron_b
Ron
SF Bay Area, USA
Well @dryii and @Denham in the video above https://www.taycanforum.com/forum/threads/new-porsche-owner-needs-help-with-homelink.832/post-16985 Paul does seem to indicate that the location-based technique does not always work, I don't know why and I don't have the car to test it yet myself.
Denham
Maine
KensingtonPark
New York, NY
2020 Audi A7
This is probably because the location-based HomeLink in VW cars does not work the way you expect. All it does (in Audis, and VWs at least) is that it raises an alert notification that you can pull down and press to open the garage door. So, instead of a swipe and a press, you can simply press the alert and it can open the door. The problem in my experience (with multiple cars with this feature) is that the alert appears very briefly, so if it does not do so when you are in range of the door.
epirali
Edmund
USA, East Coast
  • Thread starter
  • Thread Starter
  • #25
I have deleted and added location multiple times and it never auto opens nor alerts, so if it has a function I don’t know it.
svp6
MN
4S
Same here. The homelink did not appear despite setting up the location. I resigned to using the shortcut buttons for that.
epirali
Edmund
USA, East Coast
  • Thread starter
  • Thread Starter
  • #27
Which on an unrelated note I have found another bug for @louv’s list. I had set up my shortcuts one way for homelink and camera, I switched them to a different configuration and they won’t stay in the new configuration, they keep reverting to the old setting. Tried this many times and many ways...
lay3r3
Missouri, USA
I set the dash shortcut button to activate the garage door. If you haven't set a use for that it may be a solution for you.
dryii
Doug
Orlando, FL
I have multiple openers configured, but I'll check out your suggestion.
lay3r3
Missouri, USA
I can’t recall if it opens the list or just activated the top one. Hope it helps either way.
