Performance drop with low SOC?
TSS
Tom
Countach, Diablo SE30, Taycan Turbo, Lamborghini 5C
This may have been covered somewhere on here before but I couldn’t find much about it.
Is it normal for the performance to drop off when the car is below a certain charge level?
My Taycan Turbo has gone below 30% charge for the first time and it’s as if I’m carrying an extra 2 tonnes. It’s certainly not a fast car at the moment.
I’d like to know if other people notice this?
Thanks,
TSS
Gubbjaevel
F
Sweden
TaycanT'20
Below 30, no. But below 10%, yes very noticeable.
TSS
TSS
Tom
Thanks, that's interesting. My car is on charge now and I'll see if the performance returns when it's charged. I really hope it's not going to have to go back to Porsche for the second time in less than 250 miles from new!
Neptune
Kevin
Taycan Turbo S
It could also be a differnce between drive modes. In normal you always start off in 2nd Gear but in Sport/Sport+ you start in 1st gear.
Also its pretty chilly right now, 3 degrees in the UK probably isn't best for current flow from the battery.
TSS
TSS
Tom
I've been in Sport+ the whole time and can feel it using both gears. I agree that 3 degrees is not great for the battery, but the performance drop I'm experiencing is significant. I can't believe it is just because of temperature - Taycans in properly cold countries would grind to a halt!
Rob_UK
Yes I’ve noticed the performance drops. It actually starts at around 60% charge and reduces performance to circa 95%. By the time you are <30% charge the performance is less than 50%. The power meter will always show you both the available power and regen for breaks.
chrisk
Have you checked the instrument cluster to see if it still sends power to the front wheels? One way to drop performance is by not feeding the front motor.
TSS
TSS
Tom
Thanks, that's very interesting that you have the same experience. Mine definitely feels like a 250BHP car at the moment. I wonder if it will get better with more mileage. My dealer insists that the car does some sort of automatic "running in" for the first 1,500 miles but has so far not been able to tell me what that means. They are supposed to be speaking to Porsche and coming back to me.
TSS
TSS
Tom
No I haven't. Is there a setting to adjust that?
chrisk
It is in the leftmost column on the instrument cluster where the tire pressure is shown. If you scroll on options you can see how power is distributed between the front and rear axles. If you have PDCC you can also see how PDCC kicks in.
TSS
TSS
Tom
Thanks I'll check that next time I drive the car if the performance doesn't return after charging. I presume that is not a user adjustable thing? Is it a known fault issue?
Rob_UK
I don’t think it’s a fault more by design. As soon as I charge to my regular 85% I get full performance again. The power meter always show available power in the 12 to 6 position clockwise. Regen for breaks is 12 to 9 anti-clockwise. I can’t find any documentation on this which is frustrating.
NC_Taycan
Lewis
Wake Forest, NC
Turbo (non-S) - I haven't noticed a performance drop until 20% - 30%, but that was on a track day. I also haven't been looking for it. Now I have a reason to hold off charging for a few days and do some more launch control tests. <evil grin>
Rob_UK
I think is more noticeable without launch control. Take a pic of your central display power meter when your battery is less than 50%. I’m prepared to bet the meter will show you operating at less than 80% power.
Smithy37
Mark
My SOC was 30% today and it’s cold outside (1 degree C) and mine didn’t feel as sprightly as usual. Wasn’t all down to traction, or lack of, neither.
