smoothound
- Alan
- Mar 13, 2021
- North West UK
- CT Turbo Acid Green PTS
- #1
Folks
Previously the standard equipment was a 'Mobile Charger Plus' - which differentiated it from the more expensive/sophisticated 'Mobile Charger Connect'
Just noticed the standard equipment description is now simply 'Mobile Charger'
Also, for some time, the 'Mobile Charger Connect' is no longer available on the configurator. At least I can't find it.
I have also seen some threads here noting that the standard charger (the plus) may be upgraded because of overheating...
Do you know if the standard charger supplied with the car has changed spec? ...... For example, is the default now the 'connect' version? .......Has it been beefed up? .........Or is it just it just a text omission/change of name?
I ask because I have just had a 32A industrial socket fitted in prep for Taycan arrival - and I was going to make a nice lined wooden wall box to mount the charger in based on the dimensions of the 'Mobile Charger Plus' - but if it has changed I will need to check any new dimensions etc.
cheers
cheers
