moto_geek
- May 6, 2022
- US
- Taycan 4S w/Sport Package
- #1
I'm going to try to keep this short.
Problem: We hit a pot hole this spring with our 21" Winter wheel and tires., I confirmed a bent 21 mission wheel. Hoping this was going to solve the problem as it felt pretty significant enough vibration in the steering wheel and passenger felt this vibration in the seat and floor.
Diagnosis 1: Confirmed at tire shop wheel hop when spun. Purchased a used wheel replacement with a good spare and got rebalanced an installed hoping my problems fixed.
Problem Still There : I was already little concern the problem has cause issue to the axle and/or motor as well. So I swap the front wheels left to right as well so I knew the good wheel was in a different position and the wheel that didn't hit the pot hole was on the problem spot to see if I get a different issue.
Diagnosis 2: Ok maybe the other Winter 21" wheel had an issue too. So I replaced both fronts with my set of Summer 21" wheels and tires that have the same tread depth as the Winter set. The problem is a tiny less noticable but still can feel a significant harmonic vibration from about 65 mph to 80 mph. It gets stronger the faster I go.
So I feel I ruled out wheels/tires and I tried a completely different set of wheels that were fine last summer and now suspect a problem in the axle or or worse motor. Is there any further self diagnosis I can do before taking it to the dealer or recommendations? Anyone else ever experience this?
