fgwinn
- Aug 31, 2021
- Philadelphia
- MY22 FBM CT4 (sold), MY23 EQS 450 4Matic SUV
- #1
I am planning to install a front view camera on my MY22 CT 4 to facilitate parking at the EA charging stations. My car does not have the factory installed surround view camera option. I am trying to decide on the approach to use for powering the camera on/off. I do not want to install a switch anywhere inside the cabin and I don't want to operate the camera continuously. Here are the possibilities I am considering. I am not certain if these options are really feasible and I invite any comments, criticisms, or suggestions.
1) Inexpensive timer relays like this one can be configured to turn on an accessory for a specified time after receiving a trigger signal.
https://www.amazon.com/gp/product/B083HN673G/ref=ox_sc_act_title_1?smid=A1YGHK4VRDPUC4&psc=1
Possible choices for a +12v trigger signal could be the horn, the light above the Sun visor, or one of the pins in the bicycle rack power socket. A tap on the horn or lowering the Sun visor could trigger the camera to display for five minutes or so. Depending upon what signals are available in the bicycle rack socket the trigger could be reverse gear, a turn signal, stepping on the brake, or perhaps even turning on the rear fog lamps. Engaging the front camera by shifting into reverse may seem silly, but if the timer is set to be on for five minutes it would definitely be workable.
2) I don't know much about external garage door receivers, but I think one like this unit could do what I am trying to accomplish.
https://www.northshorecommercialdoor.com/gurx5exre.html
The way I envision this working is that the receiver would be programmed to use the same signal as my garage door. When I am home pulling into the garage turning on the camera could be useful. When away from home the receiver would be used to start the camera. Since there is no timer function in the receiver, the camera would have to be manually turned off by pressing the garage door button again. Since the receiver has two channels, it would be possible to power on another accessory by programming another remote.
3) A combination of #1 and #2. The garage door receiver could supply the trigger signal to the timer relay. That way I would not have to remember to power off the camera.
