zenoliu
- ZHEYU
- Sep 7, 2021
- China
- Taycan 4s,992 Carrera S
- #1
I purchased the Taycan 4s with PSCB system 1 month ago and I got great experience during this period.What's strange is that when I use the brakes in the morning, the brake pedal will make a crisp clicking sound when I start up for a while recently.The sound will disappear after about 5 to 10 minutes of driving.
When this sound is present, the kinetic energy recovery function is disabled when I apply the brakes.When the braking action is carried out, it is obvious that the brake system is working.(The bad thing is that I didn't notice before that the kinetic energy recovery system could not work when it was just started)
Recently Shanghai just entered the autumn, the weather is still very hot,So it is unlikely that the kinetic energy recovery cannot be used because of the low temperature.
When the sound disappears, the kinetic energy recovery function returns to normal,The brake pedal can be depressed to apply the brakes through the kinetic energy recovery system instead of using the brake system.
When I arrived at the office and started up again after staying there for more than 4 to 8 hours, the strange sound reappeared.But if I start the car between 1 to 2 hours, then the sound will not appear.
I would like to ask if you owners have encountered a similar situation? Thank you very much!
I recorded a video, because the phone radio capacity is limited, you guys may need to turn on the maximum volume to view.Thank you very much!
