Range mode carries a 4S 330 miles (531 km) on the highway in the summer
Kingske
Kingske
New Jersey and Colorado, USA
@Kingske I think you are right that the useable battery capacity could be a little higher than the stated 83.7 kWh or at least the SOC reported by the software is is a bit of a moving target. I got these readings which shows the time spent at 100% SOC appears to be temperature dependent.
Time spend at Indicated 100% SOC. Target speed was 71.5 mph.
Minutes into tripAir Temp ~15.8FAir Temp ~36FAir Temp ~53FAir Temp ~69F
0100100100100
2100100100100
49810098100
6979797100
8969797100
10959696100
1294959598
When the air temp was ~69F it took more than 10 minutes for the battery SOC to drop below 100%. I remember wondering at the time if something was broken but ended with a 300 mile range test.
That is an intriguing observation!
JimBob
Toronto Canada
I think the high tire pressure may be an important contributor. Sometimes I wonder whether it is too high...
I do like the higher tire pressure for distance driving. And you are still in specs. Maybe not quite so good for cornering.
JimBob
Toronto Canada
my Guess is that you are right. After the software update my range went up a lot. Guessometer is consistently above 300 and as high as 330.
This one is testable. I have not had the WMA5 update yet so am curious if Porsche could have stuck a range increase in without telling us. Just not been hot enough yet to do a test. No heat bubble here!
Kingske
Kingske
Would be an issue if I would be meandering down a mountain road in the Rockies or zooming along the Pacific coast. Quod non. This is New Jersey where most of the aggressive steering work is devoted to avoiding potholes.
