Regenerative Braking above 100% SOC?
Squiden
Josh
Denver, CO
Taycan GTS ST
I live near the top of a decent hill with ~700 ft descent over a couple miles to get down to town. I usually charge to 85% overnight, and because of the mostly downhill ride, I actually get into town at 86%-87% before getting on the Freeway and start to eat into the battery. Does anyone know what happens if I was planning for a long road trip and wanted to charge up to 100% overnight - would regenerative braking try to charge above 100%, or is the braking logic smart enough to know not to charge, and instead use the caliper brakes until the battery is <100%?
feye
Shenzhen
Porsche Taycan 4S+ 2020
Recup is very limited with 100% charging. You have 2 options:
1. Charge to 95% and take the "free" recup energy.
2. Charge to 100% and heat up the friction breaks a bit.
kort
'21 taycan 4s
there is no regen when at very high SOC levels, there is no place to put the kw gained by regen.
seskiyapan
Turkey
Maybe out of the main topic but , do you think when going downhill is it better to regen by applying the brake gently or turn on the actual regen ? I’ve always wondered..
Squiden
Squiden
Josh
Denver, CO
Taycan GTS ST
Thanks everyone! That was my assumption, but didn't know in-practice how Porsche set the system up.
In terms of regen, I usually try to use the auto-regen when possible - while I think they are equally efficient, the "slower" regen will be easier on the battery and create less heating in the system, so overall a bit healthier for the battery (albeit, likely in the noise compared to the major charging cycles).
rs38
west germany
taycan,gt2,i8
try it! there is always regen at 100% but way less. it could get to 101% as the shown SoC is only a calculated net value, not comparable with Tesla. Be also aware that (at least my) Taycan have a short non-regen brake cleaning timespan every morning.
