RWD Sport vs Sports Plus
DACSarasota
Doug
Sarasota, Florida
22 Taycan RWD
Greetings!
I just drove a RWD without sports chrono. I hit the sport mode button on screen (super easy to do) and was able to do launch control.
While the Chassis has a "sports plus" function, I understand it is not a true sport plus function that can only be obtained if you have the sports chrono knob.
Can someone please explain to me the difference between sports plus (through chrono) and sports mode /w sport plus on chassis (without chrono)? Does it make much difference on a RWD, as right now I am reconsidering optioning this feature?
XLR82XS
LXA
SW FL | Vegas
In PSM SPORT mode, PSM support is limited in critical driving situations outside the ABS control range. PSM SPORT mode should always be switched off during "normal" driving.
*Vehicles with Sport Chrono package:
In PSM SPORT mode, the system is switched to a particularly sporty mode.
The PASM suspension system actively adjusts the chassis dynamics.
Your vehicle may be equipped with one of the following versions:
– PASM with steel suspension.
– PASM with selectable air suspension and levelling system
The adjustable chassis system individually sets the appropriate damper force level for each wheel.
3 different chassis setups can be selected at the push of a button:
– Normal: comfort setup
– Sport: sporty setup
– Sport Plus: very sporty shock setup
Suspension modes can be manually set to whatever you desire. Example: sport suspension in NORMAL drive mode. Chrono option is worth it IMO for anyone that wants more from their Porsche than just driving to the store, work, etc...
PDACPA
PDA
Tampa, FL
@XLR82XS Thanks for the detail. Ordered mine with both Sport Chrono and Active Air Suspension. Now if Porsche could find some TPM chips I could actual get it and try out all the settings! :mad:
XLR82XS
LXA
SW FL | Vegas
@PDACPA you're welcome! SC and air suspension are key. I feel for all y'all that have to wait. I got lucky an my RWD arrived in ~7 weeks from order. ?
DACSarasota
DACSarasota
Doug
Sarasota, Florida
22 Taycan RWD
I may be dense....having trouble understanding this. Would someone be able to boil down for me?
Is PSM Sport Mode what happens when I press the Sport button on the RWD (with no Sport Chrono)? Are you saying that it is much more limited than if I accessed it from Chrono?
I can still adjust the Chassis from the menu system without Chrono.
If it helps, I am getting the air suspension option.
XLR82XS
LXA
SW FL | Vegas
No. PSM sport: tightens the suspension. SPORT button on center screen is sport drive mode.
smohr33
NY
Taycan 4S -> Taycan CT4
PSM is stability management. More yaw, slip angle, etc; not suspension related.
DACSarasota
DACSarasota
Doug
Sarasota, Florida
22 Taycan RWD
PDACPA
PDA
Tampa, FL
Thank you. That is helpful, but wondering if that is more geared toward a Turbo or even a 4S.
With the RWD, not sure if you can tell a big difference.
If my RWD would get its TPM I could maybe give you an opinion! LOL Its stuck in the port waiting on the part.
smohr33
NY
So PSM only comes with Chrono option?
No. PSM is Porsche stability management (traction control, stability control) standard on every Porsche for years. PSM sport is just sportier programming for the stability/traction system, only with sport chrono. You can still defeat PSM entirely without sport chrono.
The answer to your original question, sport vs sport plus drive modes is likely pedal mapping, steering weight, and availability of PSM sport. No more power, launch control works in either, and suspension settings are independent of drive mode.
I’ll go against the grain and say it’s not needed on a Taycan and not as valuable as on an ICE Porsche where you get dynamic trans mounts, different PDK shift logic, launch control, PSE changes etc.
