Sat Nav limited speed to 90mph which is fine. All of a sudden it slowed to 70mph for half a minute and then back up to 90. Please why?
H20
Robert
peebles
Ford Kuga; MG Midget; Ford Transit Connect
r553
Rockledge FL
2016 Boxster Spyder, 2015 Cayenne Diesel, 2014 Mazda 3, Taycan 4s on order
A hole in the database?
Td78
Colorado
I think the system adjusts the max speed briefly when it recalculates the route. At least that what seemed to be causing it on a road trip I took.
You can turn off the option that lets the system limit the speed in range mode. It’s somewhere in the drive mode options.
plumandreal
718 GT4
Was the car in range mode? Range mode appears to ignore the settings of the limiter and set new limits at will. (Dependant on Nav and traffic conditions). I had it happen yesterday where all of a sudden I got a limiter set at 50mph (on the motorway). Really annoying (and potentially dangerous). Both range mode and the speed limiter can set their own limits depending on what mood they are in (In range mode it tells you under the words 'Range Mode' - and it then ignores the main limiter setting).
wemct
Georgia, USA
Porsche Taycan 4S, Aston Martin DB11 (V12), Maserati Levante S GranSport, Porsche Boxster S
I believe that in range mood it is also impacted by the speed signs on the roadway. I noticed that my max speed in range mood changed depending on the speed limit on the motorway/highway.
AxelC
Finland
Porsche Taycan 4S
I experience the very same issue right now. With range mode activated, the max speed is limited to 90 km/h - also on a motorway with 120 km/h speed limit (which the car identifies). Now, I’m pretty sure that previously I could change this limit set-up up to 140 km/h, but now I cannot find that setting anywere in the PCM. Very frustrating and also dangerous!
Gogs
Gordon
Aberdeen, Scotland, UK
Can that be turned off by switching off intelligent range thing in satnav??
AxelC
Finland
Porsche Taycan 4S
I don’t have the Intelligent Range Manager, which is an option in Finland, so it must be something else.
Do you have the PCM capability to adjust the max speed limit in Range mode? I recall it being a type of slider (up to 140 km/h), but can’t find it anywhere any longer...
Gogs
Gordon
Goto nav, click 3 buttons. Scroll down and there is a setting in there about using Porsche range or something like that. I turned mine off today but have not tested yet.
AxelC
Finland
Porsche Taycan 4S
Yes, mine is off as well, but the instrument cluster still looks like in the photo... Can’t get pass 90 km/h even with kickdown.
AxelC
Finland
Porsche Taycan 4S
Manual states that Range mode max speed can be adjusted (see the screenshot with light blue highlighting), but my menu looks like in the two other pictures It’s simply not there anymore.
Gogs
Gordon
I’m sure I could kick down. It went from 90 to 55 with me whilst changing destinations. I was on the motorway when it dramatically slowed down. Not very clever.
@AxelC
You do have some problem with your options list! Here are some screen shots of mine.
I don not have Intelligent (???) Range Manager and have not used the PorscheCharge Planner. I hve the possibility to adjust the speed.
AxelC
Finland
Porsche Taycan 4S
Thanks @Scandinavian ! So I remembered correctly. And now, to make things even more complicated, as I initialised the factory settings (re-set as per Porsche Support’s suggestion), it didn’t resolve this issue but it caused also the vehicle’s Wifi to disappear... . Wifi settings are no longer available (see photo where I only have “Phone settings” and Bluetooth settings”), and cannot connect (any) phone to car Wifi...
Advertisement
Advertisement
