Ireland
Taycan Turbo S, Fiat 500 EV
Charger: Zappi v2
Rate: 7.2 kWH
Installation Location: On pillar at my dedicated parking spots in shared underground car park under my apartment
Country: Ireland
The charger requires a PIN to be entered before starting the charge (immediate or timed), protecting the charger within a shared parking environment. The charger is routed back to my existing apartment meter.
Porsche Taycan Show your home charging setup for your Taycan IMG_6239
Porsche Taycan Show your home charging setup for your Taycan IMG_6226
Porsche Taycan Show your home charging setup for your Taycan IMG_6225
struther
Brad
Toronto
Nissan GTR, Nissan 350z
Porsche Taycan Show your home charging setup for your Taycan AAC6F0B4-3653-4675-A076-91F4EE06D980
Here is mine at four floors below grade. Still waiting for the car though. The charger is Flo, which is made in Canada and very sturdy construction. The box to the right of the charger allows me to disable the charger and lock it. Handy in a shared space just in case. I had to also install a separate meter for my condo. Total cost including legal work with the condo was about $10,500CAD. Ouch!
Pozuelo
Roberto
Madrid, Spain
2020 Taycan Turbo S, 2018 E63S Estate, 2023 A45S
Charger: Zappi v2
Rate: 7.2 kWH
Country: Ireland
Here you have few photos of my setup with three-phase in Europe (22kw).
Porsche Taycan Show your home charging setup for your Taycan D1B9E654-34C7-4A5F-B1B5-5E492398829C
Porsche Taycan Show your home charging setup for your Taycan 985E3682-C6A4-46CB-87B0-A33864A5A7A1
Porsche Taycan Show your home charging setup for your Taycan EF4BA5A5-0645-4878-A50B-B8DB31CFE15F
Porsche Taycan Show your home charging setup for your Taycan 3F4222A7-78BD-4E8F-A770-93FFCF641ED6
Pozuelo
Roberto
Madrid, Spain
A photo of the Porsche Home Energy Manager unit and one of the sensors for it. I ordered 6 extra sensors to cover all three phases of the charger, home consumption load and solar panel output. Probably overkill like most things in my life... Overkill should be my middle name !
Porsche Taycan Show your home charging setup for your Taycan tempImageQqrDtf
Porsche Taycan Show your home charging setup for your Taycan tempImagefMKESw
CrazyHorse
Johnny
Taycan 4s
Hi @Pozuelo , I’m new to this forum. I own a Taycan 4S which I just received Oct 3 2020. I am probably one of the very few having a Porsche Home Energy Manager system within the realms of the USA and its Territory's; as I learned later after I bought it and installed it that this Porsche Home Energy Manager System option is not one available within the USA. That said I have mine installed and “WORKING”, in my case I have 6 Current Sensors (CS’s) or Current Transformers (CT’s) as sometimes they are called. This CS’s are connected to 1-Home 2-Taycan 2020 3-Cayenne Hybrid 2017. What I have Not be able to do is to connect the systems through my House WiFi Network and I would like to know How You did that? Did You used the WiFi antenna ? and if so how where you able to input your Wifi system Password onto the Porsche Home Manager. On the other hand did you instead connect it to your Wifi via hard wired cable instead?
Please help as I am sure that once I get this done I am done. Btw the Cayenne even thought is connected at the Home Energy Manager is only at the CS’s point of contact in order to get consumption read, its Not managing the Cayenne as it cant.
Btw for reference a few pics of my Home Energy Manager as Installed today. Thanks in advance for your help and anyone else on this Matter.
Porsche Taycan Show your home charging setup for your Taycan 942C4DDD-201C-4E0C-A9F8-986B500AB753
Porsche Taycan Show your home charging setup for your Taycan 7B758BAF-844A-4FFE-B236-D20AE2E8337A
Pozuelo
Roberto
Madrid, Spain
My Home Energy Manager is connected to the home network by Ethernet connection. It also has a direct connection to the PMCC via PLC through the very large section insulated wiring connecting the 130 meters between my utility ‘s company and solar inverter’s access point and the PMCC. Also, the PMCC is connected via WiFi to my home network. But (go figure) they don’t speak thru the home network ! They have the Ethernet and WiFi to be accessible from the internet. Hope this helps somewhat.
Phoenix
Francisco
Spain
997 GTS, Taycan Turbo
Actually, I'd like to know what functions the home manager offers...any way I can look at the manual or feature set? I'm trying to look for it, but without luck
CrazyHorse
Johnny
Taycan 4s
You should find it in google quick search porsche home energy manager manual and all PDF Files are available
Pozuelo
Roberto
Madrid, Spain
Only have the PDF in Spanish. The multiple different paper manuals are multi-lingual...
CrazyHorse
Johnny
Taycan 4s
the best and simplest way is to google the manual. It will come out in Multi-language instructions, just as the book that comes with it
jimshadow
Jim
Indiana
2020 Taycan 4S, DB9, 599, Denali, X1, Tiguan
Outlet swapped to NEMA 14-50 @ 30Amps yesterday. Charged the (new to me) Taycan from 20% to 100% in about 7.5hrs. I'll evaluate whether I want to bump up to 50 Amps over time.
Mounted the charging unit this evening. Ready to roll now!
Jim
Porsche Taycan Show your home charging setup for your Taycan IMG_1870
Lowpue
Puget Sound
1967 912, 1995 911, 2000 911, 2001 Boxster, 2002 911 4S, 2014 TurboS, 2015 Huracan, TTS ordered
One hour job to add circuit.
Porsche Taycan Show your home charging setup for your Taycan PXL_20201009_004658799 - Copy
JamieG
Jamie
Bolton
Range Rover Velar SE
Had mine fitted today. Just need a car now.
See you've gone for the Porsche UK Recommendation - Andersen. I'm looking at them too. I don't suppose you could show a picture of the interior of your garage? Hoping for a tidy finish!
4SJB
Jonathan
Taycan 4SCT Mini Cooper S Audi A4 3.0 TDI
@JamieG Had mine fitted Monday, awaiting car now.
The Electrician was on site 6 hours and did an amazing job. I could not have done it neater myself.
He did everything he could to hide the cable.
Not cheap but absolutely worth it and so much better than having cables hanging of a hook at the front of your house. Different if it is in a garage or barn.
Porsche Taycan Show your home charging setup for your Taycan DE1A4BE6-1D92-48D8-B5E1-FE283641F134
