Porsche mobile charger connect in the Uk would charge at 7.2 kwh if you have a single phase 40amp circuit breaker and set the settings on your charger to have max current 32ampThanks for the feedback. The unit is 9Y0.971.675.BG. When I connected it, the maximum I could choose was 16 amp. Plus, I’ve only got a single phase supply. I’ll report back when the Anderson unit is connected.
Now with my temporary stableTemporary installation, I'm waiting for spring to build a befitting stable for all the ponies
Yes, indeed. But the 360 view in the Porsche is incredible. Best I have ever had. Turn on the 360, forward view where you can see the sides of the car and you can literally put it within 1/2 inch. Excellent. But indeed, it's tight.That's a tight fit at the front of your garage!
Det er en smuk opsætning!My setup using the supplied charger. Installed with 11kW chargespeed since car doesn’t support 22kW (house and charger does ?).
Hi,A photo of the Porsche Home Energy Manager unit and one of the sensors for it. I ordered 6 extra sensors to cover all three phases of the charger, home consumption load and solar panel output. Probably overkill like most things in my life... Overkill should be my middle name !
