steering wheel vibrations and tire noise
Fletch
Austin, TX
‘22 CT4S, ‘21 Defender 110
first - i know there are some other posts on this but i think they may be different. This is my first porsche so not sure if this is just a thing.
i just got my 4S CT a few days ago (21" summer tires). Went for a longish ride today on fast, new roads (literally asphalt was still being laid).
  1. on the new pavement, i would here what sounded like faint whale songs. seemed to happen around 60-75ish mph
  2. i could feel every little bit of the road in the steering wheel. Not like corning feedback, just going dead straight i could feel the texture of the pavement in the steering wheel. on old asphalt this would vibrate enough to make my fingers start to tingle (being dramatic, but trying to describe it). Not shaking, no movement you could actually see, but you could definitely feel it.
curious if this is normal stuff.
edit - i was in "Normal" mode the entire time. didn't think to change modes or see how accelerating or braking would affect it. will try to reproduce.
Mathys
Heerlen NL
2022 X3 30e
Which exact tires are fitted to your car?
Fletch
Austin, TX
Sorry not sure why i didn’t see this reply
They are 21” Pirelli P Zero
The app reports they are all 45 psi (+1)
GTS ST, Macan T
I'm tempted to say this is normal and part of the Porsche setup - feeling the road rather than be numb from it. 21" tyres and rims will feedback more due to the lack of rubber (tyre profile).
ciaranob
@Fletch
Have same car, tires and wheels and the recommended (full load) cold tire pressures are rear 45 but front 41 - I actually usually run about a couple of PSI lower and few PSI less if half load (x-check manual) - might want to adjust your front tires at least.
The other thought would be what was your prior (or still current altn) ride? Just curious as to what you are comparing against re noise/feel as this car is super quite in the cabin and any and all road noise most def amplified which takes time for your ears and senses to recalibrate to!
rim23
I can also feel that. Looks like it’s normal? I didn’t experience that with my previous bmw. Though I like this feedback more :)
