Advertisement
Stuck in Southampton!!!!
lucan6699
lawrence
uk
taycan, bentley
Right. Any one local to Southampton with a charging cable????? Really fed up with the amount of public chargers in the uk that don’t work, or work then go red, or stop charging after a few minutes. Stopped at 5 stations on way from Essex to Southampton. Now need to get to Somerset and am sitting in Asda car park next to a charging station. But no cable!!! Ahhhh. Porsche assist (aka the AA), have quoted 4 hours to send a recovery truck.
lucan6699
lucan6699
lawrence
uk
taycan, bentley
  • Thread starter
  • Thread Starter
  • #2
Ps, yes I should of bought my cable with me. I had a full charge. But have done 450 miles and just assumed (foolishly) that I could get a charge somewhere on the m3/m25 etc!!!!
HK111
Henrik
Germany
Taycan 4S, Corvette C7 Stingray, Mercedes GL 320, Mercedes V 4Matic
I can't bring a cable across the channel but in any case: Fingers crossed for a resolution, best of luck!
lucan6699
lucan6699
lawrence
uk
taycan, bentley
  • Thread starter
  • Thread Starter
  • #4
On way to (hopefully) a charger.
Gogs
Gordon
Aberdeen, Scotland, UK
Try DC chargers. They are always tethered. In the UK most AC chargers require a Type 2 cable. But your road tripping so DC is faster at charging that AC.
lucan6699
lucan6699
lawrence
uk
taycan, bentley
  • Thread starter
  • Thread Starter
  • #6
this one? I didn’t think they fitted. I have been using a ccs.
Gogs
Gordon
Look for DC with CCS connection. In Scotland all the DC chargers I’ve been at have both CCS and Chademo, which does not fit.
lucan6699
lucan6699
lawrence
uk
taycan, bentley
  • Thread starter
  • Thread Starter
  • #10
Did you get sorted?
Yep. Thanks.
Recovery truck to rownham services. A little embarrassing. But got charged up and hone to my trusty pod point.
SteveMc
Glad you got it sorted.
Were the chargers you found to be problematic all Ecotricity ones (just guessing)? Did you use Zap Map app to check availability / functioning of desired chargers?
Just trying to see if there are any tips or pointers you can share with us, thanks?
Jdqt458
Uk
Cayenne Coupe
So what’s the advice.from existing Taycan drivers to ensure
your distance drives are protected ?.
Singularity
Finland
Audi A7, Taycan 4S Performance Plus
Always have a type 2 cable with you so you can top up from the slow chargers which don't have a cable. Note this cable will fit into the small storage compartment below the trunk floor, so it doesn't actually affect anything to keep it there at all times.
For a true roadtrip I would bring the mobile charger with me as well which includes a regular electricity plug and three phase plug. But on every trip I recommend having the type 2 cable in the car at least.
lucan6699
lucan6699
lawrence
uk
taycan, bentley
  • Thread starter
  • Thread Starter
  • #14
Yep. You guessed it. Ecotricity didn’t work at fleet services, lakeside Thurrock, clacker lane.
lucan6699
lucan6699
lawrence
uk
taycan, bentley
  • Thread starter
  • Thread Starter
  • #15
Yep. Type 2 lead in my car now. I had one for the xc90 hybrid we have and also a lighter 3 point plug lead - so will carry both now. Other advice is if you find a decent dc charger when out. Use it to give you the miles you need for that trip. Plus a few more. My problem was I used the first dc charger to get me to my destination due to time constraints. Thinking I would just do the same there to get back. Obviously that plan did not work!!
Advertisement
