Taycan 2022 battery issue.
Jguadal
Jose
Puerto Rico
Taycan Base
I charged my Taycan at 95% or 216 miles, but when I completed the charge and disconnect the port, the miles went from 216 to 201 miles with the car in parking. I did not move the car. i have seen this behavior in the Last 5 charges. I would like to know if this situation is normal or not.
tomtom901
Tom
Netherlands
Taycan RWD ST
Did you have pre-heating or cooling, which reverted back to normal A/C when you disconnected the charger by chance?
FlyingPoint
Cobblestone
Taycan RWD, GT3
The range estimator is meaningless as too many factors could create this. Did your SOC decline from 95% to 91% or 92%?
BMonte13
Brian
2022 Porsche Taycan
Yep I agree that the answer lies somewhere in the preheat and/or AC/heater settings.
Yes, differences/decreases in guess-o-meter range estimates from reading at end of charging to later without moving the car are normal.
Also, while you are driving, watch range changes when you switch AC/heater between AC, ECO, and OFF. It is an estimate/guess from the guess-o-meter.
Not only is remaining range an estimate, but as I learned from some posts by @ciaranob, so is battery state of charge. The indicator that says battery is 46%? It is a guess, too.
andix
Munich, Germany
SOC is a calculated value. The actual state of charge (SOC) of a battery depends on parameters (temperature, pre-heating, ...) and the range depends on parameters (previous consumption...).
So, this is absolutely normal.
RAHRCR
Northeast, US
Panamera Sport Turismo 4S
When my car is in the garage after a charge (and it’s generally warmer in there) and I exit into much colder temps, my range gets recalculated based on the outside air temp. I think what you are seeing is normal.
xyeahtony
Tony
Baton Rouge
23 Integra 6MT, 23 CT4S
Things like this makes me realize why Tesla doesn't use a guess-o-meter and just lists the EPA rated range regardless of external factors. They probably figured too many people would freak out and ask for service when their range rating suddenly dropped after driving outside.
WasserGKuehlt
WA
4CT, 996C2, MacanS
Sorry, not getting this. Tesla’s EPA range is longer than actual range, so people would freak out even worse, right?
FWIW, I find the P-car range to be spot on, especially if you put the destination in the nav.
tomtom901
Tom
Netherlands
Taycan RWD ST
One thing Tesla actually did better was the option to display % instead of miles / km's in the main screen. While the distance can vary, SOC does not. Porsche should give this option this too.
WasserGKuehlt
WA
4CT, 996C2, MacanS
Right, Porsche have put this info in the instrument cluster, which Teslas don’t seem to have? 😁 In the same screen, at a glance, I have SoC (numbers and gauge), remaining distance to empty, time and distance to destination, and ETA. Can’t think of anything missing. (instant consumption?) Estimated SoC at destination is a side glance away (on the central display).
