Kingske
- Frank
- Jun 6, 2020
- Princeton, NJ, USA
- 2020 Porsche Taycan 4S, 2014 BMW 3 GT
- #1
Indeed.If I did the math right, the first 40 miles (100% -> 72%) consumed 28% of the useable battery capacity (83.7 kWh) or 58.6 kWh/100 miles. That was normal driving, likely with a cold battery and heating the cabin. The range test part of the trip (in range mode with a warmer battery) consumed 62% of the battery (72% -> 10%) or 29.5 kWh/100 miles. That second part of the trip would tell you 100% -> 0% range, starting with a warmed battery, driving in range mode should give you 283 miles. If you were to give yourself a bit of buffer - e.g. using 85% of the available capacity, that's 241 miles.
1. If you navigate to a known DCFC then the car will automatically preheat the battery....which brings me back to my bug-bear - how do you warm the battery before getting going? So far, I've only seen the battery (slowly) warm slightly as a consequence of charging. So if you are not charging extensively just before leaving, you end up with a cold-is battery, and the first 40 miles of your journey has huge consumption, meaning you get no where near 280 miles on a full charge in cold weather.
I have had good luck with #3 independent of any efforts to pre-heat the battery. Jus sayin...1. If you navigate to a known DCFC then the car will automatically preheat the battery.
2. If you have Sport Chrono then put car is Sport+ for last 20min if trip. remember that it lowers your suspension but you could override that and put it back into normal when you arrive and plug in. In Sport Plus the battery will preheat.
3. If you can drive aggressively in sport mode preferably upon arrival or near arrival the battery temperature will climb substantially. Aggressively equals hard accelerations, heartbreaking repeatedly until nauseous.
I personally have good luck with number one and also tried number two successfully as well. Bjørn Nyland videos show #3 but generally on cars that do not instill as much ill effect as the Taycan.
That's what I've been doing, but it doesn't seem to move the dial more than a few degrees C for me.I would suggest running the cabin heater while car is plugged in and charging…that should place demand on the battery and both the current draw & charging will heat the battery.
Yup, the question was more in relation to pre-heating the battery before getting going. An option that heats the battery when the car is hooked-up to the charger would've been great, so that you don't have to actually have the car charging (for example, if the car is already charged to 85%) to heat the battery. That all said, I will be trying #3 purely in the interests of science.I have had good luck with #3 independent of any efforts to pre-heat the battery. Jus sayin...
Just get a super long charging cable and do some launch controls back and forth in your driveway.That's what I've been doing, but it doesn't seem to move the dial more than a few degrees C for me.
This is a problem. I know the documentation states that the car should preheat the battery to a certain value when plugged in and using the pre heat function. I have tried this a few times now. I have tried to plug the car in, start preheating in the car once and also via the app once. None of these methods did anything.That's what I've been doing, but it doesn't seem to move the dial more than a few degrees C for me.
Indeed, which is not really ''real life'' range... where you sometimes park your car outside in the cold during 6h without being plugged in...If I did the math right, the first 40 miles (100% -> 72%) consumed 28% of the useable battery capacity (83.7 kWh) or 58.6 kWh/100 miles. That was normal driving, likely with a cold battery and heating the cabin. The range test part of the trip (in range mode with a warmer battery) consumed 62% of the battery (72% -> 10%) or 29.5 kWh/100 miles. That second part of the trip would tell you 100% -> 0% range, starting with a warmed battery, driving in range mode should give you 283 miles. If you were to give yourself a bit of buffer - e.g. using 85% of the available capacity, that's 241 miles.
Definitely suggests warming your Taycan for an hour while still connected to your charger is a good cold-weather trip strategy.If I did the math right, the first 40 miles (100% -> 72%) consumed 28% of the useable battery capacity (83.7 kWh) or 58.6 kWh/100 miles. That was normal driving, likely with a cold battery and heating the cabin. The range test part of the trip (in range mode with a warmer battery) consumed 62% of the battery (72% -> 10%) or 29.5 kWh/100 miles. That second part of the trip would tell you 100% -> 0% range, starting with a warmed battery, driving in range mode should give you 283 miles. If you were to give yourself a bit of buffer - e.g. using 85% of the available capacity, that's 241 miles.
Use the Connect app to preheat the car (and all four seats) while still connected to the charger an hour before departing. Works well for us without ever going to the garage.@ron_b - I think the question was:
how to I get the battery to temp - prior to driving off in the morning? while still plugged in? so that you get over the inital ‘cost’ of battery warming and cabin heating…
the only way I know to do that is to pre-condition the vehicle via the timer’s profiles…or go sit in the car early and set the cabin temperature and charge it....
Interesting that it works that way. Have you seen that the power is coming from the charger at that stage? That would make a lot of sense!Use the Connect app to preheat the car (and all four seats) while still connected to the charger an hour before departing. Works well for us without ever going to the garage.
