Taycan Turbo GT?
TAYC4S
D
WasserGKuehlt
WA
4CT, 996C2, MacanS
Don't be fooled by a garish (and pointless) piece of aero - no clue that this is a GT...more weight and more besides.
I am a bit skeptical, too. However, there is some (minor) camouflage on front and rear bumpers, what appears to be a datalogger/laptop plugged in, and the steering wheel is covered. If this isn't a works vehicle/test mule, then someone is going to extreme lengths to play a prank.
And about that wing - that's a very strange contraption; I'd have expected the feet to be on the side of the trunk (as is the case with the other GT models) - as pictured, the trunk lid would need to be reinforced. If they're retractable, that'd make it awkward for trunk space, and the side flaps would seem to cover the edge of the taillights. 🤷‍♂️
Not sure if this was ever posted recently
that wing isn't going to help range…I'd rather have another 30 miles range between charges and supercharger access…
GreenHornet
Chris
Oslo, Norway
Taycan Cross Turismo 4 Mamba Green
64% and 248km is more then my CT4. 75% and 243km...
j.w.s
Jeff
San Francisco, CA USA
Opinion: I'll take the "touring" verson without the wing please.
Opinion: If they are getting ~240 miles of range out of a 1,000HP Taycan, they aren't driving it properly.
Observation: The seats are lifted straight from 911 Carrera GTS with the "full bucket seats" option.
Observation: 251kw charge rate at 64% SOC? Did they change the battery chemistry too, because that's really good. As in hard to believe good.
McgR
Taycan CT 4
The brakes look like the base ones on my CT 4. Aren’t they a bit too small for so much power ?
Winterfell
Steve
Bay Area
2023 CT 4S
If you by a GT with 1000hp, range is not your focus. The wing helps with downforce, which is what you need for traction and high speed curves.
As I don’t do extensive track days, nothing I need anyway.
j.w.s
Jeff
The brakes look exactly like Taycan full ceramic brakes with the calipers painted black option. They appear much bigger than the standard brakes, drilled like only the ceramics are, and with the bolts connecting the outer bits to the inner bits like the ceramics. This is not a surprise since ceramics are already standard on the Turbo S, so you'd expect the same on something even higher up the price/performance curve.
