maudasilva
- Mauricio
- Feb 3, 2021
- California
- Taycan
- #1
Sorry everyone for the long post. I hope it is informative at a minimum.
This a copy of my email to my dealership service department.
Hi Chelsea,
Hi James,
Porsche on copy in this message too. VIN Number WP0AC2Y17MSAXXXXX
I hope all is well.
I wanted to update you and Porsche on the status of the issues (items 1 to 13 below) reported before the last service appointment on July 30th.
Simply put things are getting worse.
Please pay attention to numbers 14, 15, and 16, in red below. These make the car unsafe. I have started seriously considering parking it at Porsche Stevens Creek and getting something else, evidently not another Porsche, but safer automobile.
1 - Recall notice - Motor control error stop vehicle in a safe place I received a notification from Porsche a few days ago.
This was taken care of I believe. I have not experienced the issue.
2 - Charging at Electrify America (EA) - plug and charge no longer works. Please see picture with correspondent EA error message. This started on June 19th.
Partially addressed as the problem happened multiple times after the last in “Service” update. However, EA contacted me the other day and was I able to show them what was going on and they fixed it on their side. Better Customer Service from them than from Porsche, whose agent emailed me three times, stating they were not able to reach you. See attachments.
3 - Slow leak in rear driver side tire - has been there since I got the car. I have to inflate the tire once a month or so. I inspected the tire, but I could not find anything wrong with it. It might be the valve.
This was not solved. I had to add air twice since the last service.
4 - Park assist error - happens quite often.
This persists and it is quite annoying.
5 - All Radio Favorites entires deleted randomly on its own - it is almost not worth it to save the stations because the next time I want to use the list it is no longer there.
This continues to happen.
6 - The car switched to "Private Mode” in the middle of a ride a couple of times.
This is still happening.
7 - Range Mode speed limit set to 65 mph - when this happens the menu for setting the speed limit for the Range driving mode is not available. I programmed it to be 80 mph, the car sets it to 90 mph when the navigation system is used. This happened today again.
8 - Menus not accessible while parked - error message and most menu items grayed out even when parked.
This did not happen again. Some progress.
9 - Car does not turn itself on upon entering the car and closing the driver door with the key with the range.
This happens almost daily.
10 - “Shrinking roof top insulation - it looks like the insulation is either shrinking or it was never uniform. Check the glass roofline outside passage side. Compare to the driver side.
Porsche was not able to contact you…
11 - Upon entering the vehicle, out of the blue, was prompted to either enter my Porsche Id, continue as a guest or switch the account. The setting is to keep me always “logged on”. Very inconvenient when your are in a hurry trying to get somewhere and you have to dig out your credentials to fully use the features of your own car.
This happened again.
12 - Trunk lid did not close 2x this past week. A friend told me that I had left the trunk open in the parking lot. No obstacle nor anything in the trunk that could have caused it. Second time I saw it. My wife pressed the button, lid goes down then back 1/2 way up.
Did not happened anymore. It might have been related to the key fob signal as you suggested.
13 - Mirrors did not unfold upon unlocking and getting ready to drive. Tried the button on the door panel no response, tried the key from the inside the car lock, unlock - no change. I had to get out lock then unlock to get them to unfold. See pics. Also notice the mirror light, one on the other off.
Did not happen like this; however, in a few instances the courtesy lights do not turn on when I approach the car.
New issues:
14 - This is a dangerous one: Porsche InnoDrive on and system does not update the maximum speed. E.g. I got to Monterey Cannery Row, with the car telling me that the speed limit is 65 mph, and speeding to that if I were to let it go that fast. Only turning the car off, cleared the problem. It has happened 4 times already and only happened after the last update. Potential recall here! See attached pic. You might recognize the background.
15 - Porsche InnoDrive has changed its ability to detect standing vehicles. It used to detect vehicles much earlier/farther and safely applied the breaks to a safe and smooth stop. Since the last update, I believe, tough to say exactly when it started, it does not detect standing vehicles well and I have to intervene, and apply the brakes myself. This is very dangerous after you developed the trust one should have on these safety features.
16 - This one is very serious: Collision Avoidance slammed on the breaks for no reason today. I had Inno Drive on and was stepping on the power pedal going through an intersection after a Stop sign. I am glad the guy behind me kept a good distance and did not hit me.
17 - Navigation menu off and on shows up in German (Ziel suchen) instead of Search Destination. This must a German SW Designer having fun…
18 - HomeLink failure - button not working. Happened a few times. I could try on two side by side garage doors. Neither worked.
19 - All Smart Lift saved locations were erased/deleted on its own.
I will need your help in getting these issues fixed, and reported to Porsche. Let me know if you need supporting images. Also, how should I proceed? Schedule an appointment?
This is tremendously disappointing. I could have gotten two Teslas instead...
Regards,
Hi Chelsea,
Hi James,
I hope all is well.
New issues:
Regards,
