OTPSkipper
- Scott
- Jan 31, 2022
- SoCal
- Neptune Blue Taycan
I open my trunk or frunk getting into the car if the keys are in my right pocket.
Good morning…it has stopped….at this point I think as I was getting out of the car/grabbing my backpack, I was inadvertently hitting the trunk button. I’ve been more careful and it hasn’t replicated.I've been having this issue lately too.. after the PCM update
OP, wondering if you were able to get it fixed?
Agreed - def sensitive as I’ve replicated this with my pressure washer wand but actually with the water jet from it and not the physical wand!! Never happens in any other circumstance and my comfort access foot kick has worked perfectly every single time since car purchased.Mine opened with the hosepipe I was using to wash it last week. It must be sensitive.
Pretty sure I’ve been doing the exact same thing. Found mine on a main road, wide open. Thought someone had been in it a first, but everything was still there.Good morning…it has stopped….at this point I think as I was getting out of the car/grabbing my backpack, I was inadvertently hitting the trunk button. I’ve been more careful and it hasn’t replicated.
You could disable the entire fob (good when washing the car) but it will reactivate when you press a buttonPretty sure I’ve been doing the exact same thing. Found mine on a main road, wide open. Thought someone had been in it a first, but everything was still there.
Is there a way to turn those buttons off on the fob?
