- Jeremy
- Feb 9, 2021
- St. Louis, MO
- 2016 Macan S; 2021 Taycan 4S; 2023 911 GTS Cab
No. Dave is saying the circuit is a 50 amp circuit but the load is 40 amps.Excellent post and one that will help a lot of users. Thanks @Dave EV.
One question: are you saying your level 5 (50 am circuit) will allow the included-with -the-care mobile charger to be plugged in and run at 50 amps?
I am using that charger at home (on a standard 115VAC 15 amp circuit) and it will only allow 8 amps without a special "charging manager."
Both the PMC+ and PMCC go up to a maximum of 40 amps if they are put on a 240VAC 50 amp circuit.
You do not get to use 50 amps. The circuit it’s on has to be a 50 amp circuit though. Circuits for continuous loads have to rated at 125% of the continuous load.
